Lincoln Welder, #AC 225-5
I have a question and not sure if this is the proper place. Recently I was given a Lincoln Electric Arc Welder, #AC 225-5. Seems to be in good shape, but has no manual and none of the welding cables - electrodes - ground. All I have is the basic box. Does anyone know where I can order or find reasonable priced parts / cables. I hate to spend a lot because I am not sure if it even works. Any suggestions.
Thanks |
Re: Lincoln Welder, #AC 225-5
As far as a manual, you can probably download one from Lincoln's web site. You may need either the model or code number or both, so have them handy when you visit the site. If you know someone who has cables that could be borrowed and hooked up temporarily, you might try that route first. Most of these type welders very rarely have a problem that cause them not to operate, so chances are good it will. Unless you were given it because it didnt work. Anyway, good luck.
A few of my toys ! LinuxMint LinuxLite Crunchbang Miller Roughneck 2E Lincoln WeldPak 100 HTP MTS 160 Chicago Electric 80amp Inverter Victor O/A |
If you're buying a lot of cable. Last time I looked around these guys beat everyone's prices.
http://www.cableyard.com/catalog/ For eletrode holders or ground clamps, I'd probably use http://www.cyberweld.com. If you want it today and don't want to wait for shipping then try the local welding supply, Tractor supply, Home depot, Lowes, etc, etc. Don't expect great quality stuff from the big box stores.
MM210, For sale $1k with cart,reg,gun,hose, and 250cf bottle Dynasty200DX w/coolmate1 MM Vintage Lincoln AC225 Victor O/A, Smith AW1A Cutmaster 81 IR 2475N7.5FP Rage3 Jancy USA101 9" SB 9" Craftsman/Atlas lathe (worn out) AEAD-200LE |
mulligan,
Is that AC-225/5 as in an engine drive unit or AC-225-S as in an AKA 230VAC "Buzz Box"? I suspect it's the buzz box but either way you can get your manual here http://www.mylincolnelectric.com/Cat...ualsearch.aspx
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
FYI, weldingsupply.com smokes cableyard on welding cable prices. So does my LWS.
