Flat vs Slanted Welding Cart
Welding carts sold at Harbor Freight or Northern Tool can be level or at a slant (angle). Are there any down side to having your TIG welder laying at a slant? Is it not good for the electronics or the flow of shielding gas? I have a Miller's Econotig.
Thanks |
Re: Flat vs Slanted Welding Cart
The gas is under pressure so it doesn't matter how the hose runs, the gas will get to the torch just fine.
Most small welding machines can run in just about any position without problems, though you want to make sure the air vents are not blocked by anything or it can overheat. The reason for slanting them on those little carts is they're so low to the ground, having them on a slant helps see and reach the controls easier. I have to say this, beware of those cheap Harbor Freight carts. I got one for free one time and that is all it was worth. It was so rickety I was afraid to put anything heavy on it and move it around. Even after I braced it up, it was still wobbly. I ended up giving it away. The steel is just too thin to hold up much of anything.
Having the box sit at an angle also makes it more difficult for it to slide it off its perch when someone tugs on the line.
This approaches a question I have. I'm a newbie. I just bought a Miller Dialarc 250 stick welder and the manual says, essentially (I don't have it in front of me at the moment), not to tip it and it even has a cautionary illustration of one being dollied up a loading ramp. Now, is that just to prevent accidents, or is there something internal that actually suffers from being tilted? I'm going to pick the welder up Friday and I don't see how I can possibly get it into my little enclosed trailer without taking it up a ramp. God! That feels like the dumbest question in the world. Thanks. Last edited by snotjello; 10-20-2009 at 09:47 PM. |
Exact phrasing from the manual (p.17): Do not move or operate unit where it could tip. ...still begs the question I posted above. Though I just read the administrative post about manufacturer-specific questions, I think this is really a question about arc welders in general, not mine specifically even though I mentioned the model. (I repent! I repent!) Last edited by snotjello; 10-20-2009 at 10:34 PM. |
When you consider what delivery guys must do to the welders that get sent across the country, I don't think you need worry. My previous welder was a heavy bugger. I often tipped it on its side or back to get it into my little trailer.
Yeah, I carry. House keys, wallet, some change, usually a newspaper, maybe a pen. |
dats just a warning to beez careful
Gravity has fooked up a lot of equipment.
Ed Conley http://www.screamingbroccoli.net/ MM252 MM211 Passport Plus & Spool gun TA 185 Lincoln SP135 Plus- (Gone to a good home) Miller 125c Plasma 120v O/A set SO 2020 bender Beer in the fridge |
Good point. |
That warning is there most likely cause that Dialarc is so heavy that if it were tip over and land on you, you could end up with a broken something on your body. My Dialarc I'm sure weighs at least 500 lbs. I'd hate to have that land on my foot!
The Miller website shows the Dialarc 250 as 360 lbs.
Yeah, not something I'd want to play catch with. |
What about cart/platform height? I heard from someone that arc welders tend to magnetically attract metal dust and stuff that accumulates on a shop floor, and that it can be harmul to it, and that it should be set on a platform because of this. Is this true? If so, how high is "safe"?
"Idealism increases in direct proportion to one's distance from the problem." -- John Galsworthy
My equipment. I'm new to welding: - Stick -- Miller Thunderbolt XL, 225/150, AC/DC - MIG -- Miller Millermatic 211 Last edited by snotjello; 10-27-2009 at 01:56 PM. |
I like the knobs about waist high if building a cart. I also don't like slanted carts, especially for MIGs. Reason being, that upward slant might make it easier to see, but you loose gun length because the lead arcs up and then back down to lay on the ground. I rarely change settings, so if I have to bend over to see the readouts or turn the knobs, it doesn't bother me a bit. I'd rather save that extra foot or so of gun length.
My name's not Jim.... Syncrowave 200 Millermatic 251 w/bottle mod Spoolmatic 30A Maxstar 150s Cutmaster 81 Jet JTM-1 mill Jet GH-1340-W3 lathe |
Interesting. Thanks.
My equipment. I'm new to welding: - Stick -- Miller Thunderbolt XL, 225/150, AC/DC - MIG -- Miller Millermatic 211 |
