Go Back   WeldingWeb™ - Welding forum for pros and enthusiasts > WeldingWeb MarketPlace > Shop, Trade, Sell Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 12-23-2009, 06:43 PM
Gooseguy84 Gooseguy84 is offline
Surplus Machinery & Equipment - 200+ items – Mills, Lathes, Presses, Welder, etc (NJ)
Hi, below is a list of all the machines and equipment I have for sale. I am not a dealer, but am facilitating the combining of multiple business into a building, and therefore have a lot of overlaping machines and not enough floor space. All machines are set up and can be viewed under power.
Please email me at BrianPore@gmail.com or call 732-882-2291 if you want to reach me fast and would like detailed specifications and pictures. I have no problem shipping UPS or Freight. Asking prices are listed next to most items, all items are obo.
Presses
36 TON L&J OBI PRESS - 3" STROKE - AIR CLUTCH - $6900
60 TON L&J OBI PRESS - 4" STROKE - AIR CLUTCH - $9900
85 TON DIE MASTER OBW PRESS - 4" STROKE - AIR CLUTCH - $9900
MINSTER 32 TON HIGH SPEED OBI PUNCH PRESS - AIR CLUTCH - $12490
150 TON V & O PRESS - 6" STROKE - FULLY REBUILT - $14900
220 TON KUKIL OBW PRESS - $29900
PRESS TYPE WELDER
Federal PA-2-12 100 KVA Press Type Welder - $7490
100KVA Jefferson Transformer, 240x480 High, 120/240 Low - $990
COIL CRADLES
8,000 Lb ROWE 8030J Coil Cradle - $5900
2,000 Lb ROWE 2020J-PR Coil Cradle - $1790
4,000 Lb ROWE 4024J Coil Cradle - $3490
2000 Lb PRE CC-210 Coil Cradle - $1900
2000 Lb LITTELL C-20 Coil Cradle/Straightener .125" THK - $4900
COIL FEEDERS
ASL 2500
1000 LBS JACO JVRE-512-DC Reel - $1990
150 LB Rapid Air RH34A Reel - $545
FEEDERS
12" x 12" PRE B15 Feeder - $2990
30" x 30" COIL-MATIC Feeder / Straightener .125 Thick - $3490
PRESS EQUIPMENT RF3030 - $1750
PRE - Press Room Equipment - Air Powered Feeder Stand - $2990
DRILLS
BOWES BR40X1250/1 Radial Drill - 12" Column & 50" Arm - $5490
Orbit 12-Speed Bench Mounted Industrail Drill Press - $299
BURGMASTER #OB 1/4" 6-Spindle Turret Drill - $1295
Walker-Turner 1216-32 - 4' x 6' steel table and vise $499
EFI. FB3 Drill Press 1HP 6 Speed Geared Head - Floor Monted- 18x36 Table - $990
VERTICLE BAND SAW
DO-ALL MODEL# 1612-3 VERTICAL BAND SAW - 16" x 12" - $3900
MILLS
OKK MH-3VII Milling Machine - $8900
Bridgeport 1.5HP Series 1 - 2J Head - DRO - Servo Feed - $2990
Bridgeport 2HP Series 1 - 2J Head - DRO - Servo Feed - $3490
SHEAR
PEXTO 152-J Shear - Pneumatic - 52" - 16ga - $1495
HYDRAULIC PRESS
60 Ton, KR Wilson Hydraulic 7G 3MD Electric Shop Press - $3490
8 Ton Denison C Frame Hydraulic Multipress - $2490
LATHE
Harrison 10-AA Lathe - 11" x 20" - Precision Tool Room - $2490
Mori Seiki MS-1250 Lathe - 15" x 48" - $3990
SURFACE GRINDER
Brown & Sharpe 1236 Surface Grinder - 12” x 36” Table - $8900
Blohm 818 Surface Grinder - 8" x 18" Table - $3950
8" x 18" Mitsui MSG-250MH SURFACE GRINDER - PMC &Filter - $5950
HONEING MACHINE
Sunnen Hone, Model MBB-1680-C with PF-150 Oil Filter! - $4490
MANLIFT
Grove SM2633BE Electric Scissor Style Lift Man Aerial - $1495
AIR COMPRESSOR
Ingersoll-Rand SSR-EP150 - 670CFM, 150HP Air Compressor - $6490
TOOL BOXES
LISTA 7 Draw Tool Box Storage Cabinet 40" x 33"- Wood Top & Extension! - $990
Vidmar Box - $800
96 Draw Steel Cabinet full of O-Rings! - $390
FREESTANDING BRIDGE CRANE
BLUE CRANE 1 Ton - approx 13.5'Tall, 26' long, 20' wide - $8990
YELLOW CRANE 2 Ton - approx 15'Tall, 18' wide, over 80' long - $4990
INSPECTION EQUIPMENT
3 Granite Surface Plates - 18x24 24x36 & 36x48 - $1490
Box 7-draw all testing equipment
Indi Square 18X - 1490
14" Jones & Lamson TC-14 Optical Comparator w/ 4 Lens - $1490
Swaure L B&D TOOL CO - $99
Angle Set Starrett Webber
Gauge Blocks Starrett Webber
Gauge Blocks .05-.4
Gauge Pins Set 13 .626-.75
DoAll Gage Blocks 81R
Mahr Gage Block Accessories
Gage Blocks Do-ALL
Gage Blocks 1-90mm Mahr - $299
Gage Blocks HDC Inc
Gage Pins 3 sets #14
Gage Pin Sets Yellow
Box of Extra Gage Pins - $35
Height Gauge Gelio 26in
Height Gage B&S 585 19" - $145
Brown & Sharpe 585 - 12" Height Gauge w/ Felt Lined Box - $150
Wheel Dresser LS TOOL
Height Master Mitutoyo
RAHN Granite Parallels
Jerry Center
Starrett Mechanic / Machinist Level 12" x 1.5" - $150
Tensitron TR-250 Wire & Filament Tension Meter Wood Box "Like New" $345
Tensitron TR-250 Wire & Filament Tension Meter Wood Box "Used" $225
Renishaw PH1
SPI 6" Universal Deep Throat Inside Caliper W/ Dial - $599
Dial Caliper 12" Long - .001" Accuracy - $50
Starrett No. 123 Vernier Caliper - 26.5" Long - $290
Starrett No. 122 Vernier Caliper - 24" Long - $65
Starrett No. 122 Vernier Caliper - 48" Long with Box - $1500
Brown & Sharpe No. 570 Vernier Caliper - 13" Long w/box - $119
Caliper ID Mitutoyo .4-1.4" - $120
Bore Gage Diatest.165-.394
Bore Gage
Mitutoyo 511-163 Bore Gage - 0.7-1.4" - ACC .0001 - $175
Mitutoyo 511-105 Bore Gage - 1.4-2.5" - ACC .0001" - $175
Mitutoyo 511-106 Bore Gage - 2-4" ACC .0001" - $165
Bore Gage 2-4" Mitutoyo
Mitutoyo 511-187 Dial Bore Gage - 4-6.5" - ACC .0001" - $325
Mitutoyo 511-214 Dial Bore Gage - .24-.4" - ACC .0001" - $290
Bore Gage Federal 1243P-3 - $150
Federal 1250P-1 Bore Gage - .5-1" ACC .0001" - $125
Federal 1204P-1R2 Bore Gage - .310-.628" ACC .0001" - $159
Pea**** 5470 Dial Bore Gage - .75-1.45" - ACC .0001" - $119
Starrett No. 220 Anvil Micrometer - 0-1" w/ Box - $99
Micrometer Starrett 9-12"
Micrometer Starrett 7-8"
Mitutoyo 1-2" Blade Micrometer # 122-126 w/ Wood Box - $150
Starrett 6-12" Micrometer # 224 w/ Original Wood Box - $290
Micrometer NSK 7-8"
Mitutoyo 7-8" Micrometer w/ Wood Box - $125
Mitutoyo 9-10" Micrometer w/ Wood Box - $155
Micrometer 12-13 Mitutoyo
Micrometer 1in Starrett
Mitutoyo 146-104 Flange Micrometer 0-1" w/ Wood Box - $99
Starrett 0-1" Blade Micrometer # 468 w/ Box - $99
Mitutoyo 147-351 Micrometer 0-1" w/Box - Looks New! - $99
Micrometer 1-2" Screw Thread Mitutoyo
Micrometer Etalon 2-3" indicating mic .00005 - $200
Micrometer Etalon 3-4" indicating mic .00005 - $250
Micrometer Etalon 2-3" indicating mic .0001 - $150
Micrometer Etalon 0-2" indicating mic .0001 - $200
Micrometer Etalon 0-1" microrapid mic - $75
Micrometer Mahr 4-6" .00005
Micrometer Starrett Case +
Micrometer Gage Starrett 12"
Micrometer Gage Starrett 11"
Micrometer Gage Starrett 9"
Micrometer Gage Starrett 7"
Starrett No. 823 Tubular Inside Micrometer 4 - 24" - $199
Starrett 700 Inside Caliper Micrometer - 1-2" w/Box - $119
Micrometer Inside Starrett - NO MIC
Micrometer Inside Starrett 4-12" Pouch
Lufkin Radius Gage Set
Shore Durometer w/ Calibration Block - ASTM D2240 - $129
Pocket Surf III - Mahr Federal - EMD-1500-311 - New - $1750
Pocket Surf III - Mahr Federal - EMD-1500-311 - Used - $990
Lyman Radius Templates - $40
Gauge Starrett - Alone
Deltronic Pins + Angel Gage
Elecometer
Greenfield Tap - 2 11 1/2 NPT - $49
NPT 2" Tap 11 1/2
Brown & Sharpe Toolmakers' Surface Plate Square 559 - $45
MTM Blocks
taper micrometer
Angle Mic / Taper Mic
Taper-Mike 311
DoAll Gage Set #9
Model M-O Plug Gages - $50
Brown & Sharpe 1.4000 Ring Gage - $99
Chamfer Gage Barcor Model# 1127 - 90-127 deg - 0-1" - $125
DoAll Black Granite Dressing Plate
Steel Stamping Letters - $40
SPI-SPE Mold Comparison Kit - $149
Microstat
Alina Copr 12" G1730
TOOLS
KURT II VISE Model # PT-800A - $990
KURT ANGLOCK VISE Model # D675 -$325
(2) SOILD STEEL TABLES - 6'Lx30"Wx35"T - 2" THICK TABLE - $1990
Kalamazoo 3HP, 10" Abrasive Cut-off Wheel with stand - $399
#15 Royersford Excelsior Kick Press - 3 3/4 Ton - $490
Greennerd NO2 Arbor Press 2 Ton - $199
Redingtion Counter - $50
Lucifer Furnace 7021-C - 6"x6"x12" - 2000 DEG F - $850
FLEX ARM S35 400rpm Tapping Arm - Very Nice Setup Table - $1990
TECO FM100 FLUXMASTER 30HP 3PH 460 VOLT MICRODRIVE - $490
PYH Demagnetizer
PELOUZE 60 LB SCALE - $99
Baldor 1/2 HP Industrial Pedestal Grinder 3800RPM - $450
Delta Triple Duty Pedestal Grinder- 1/2 HP 3450rpm - $390
(2) 5 step ladder on wheels
Setco M3BL & P3 slides
3 sided in-plant modular office - 9' x 14' - A/C - $990
Square D Class 9007 Series A Limit Switch - $99
Porter Cable Wet-dry belt sander
Fan TPI
Fan NOVA Airmaster
PAX 5-6 Oiler
Black & Decker
(2) Wilray Fire Cabinet PDCS-55
Yellow Steel Sawhorses
Rolling Cart Yellow Steel
Rolling Cart Blue - Push Handle
Dayton Welding Cart
Dayton Professional Wet / Dry Vacuum
Other
Very nice receptionist's desk - Solid Wood - Over $8000 new - $1900
1.3 Million Button Parts! - Standard Various Sizes - $9900
Toshiba DP3580 Office Coppier - Over $8,000 New!! (was working but wotn power on) - $400
(2500) 1-1/2" Nylon Sliding Door Rollers for Marshall - $1750
20,519 LBS - Tin Plate Foil Inventory - 0.0082 & 0.0105 - $7900
ALL items are being sold in as is where is condition, with no representations, warranties and/or statements of fitness and/or merchantability implied whatsoever. The items are not warranted for any particular purpose or use. All liability rests solely with the purchaser and/or his successors and/or assigns.
