Old 02-09-2010, 10:06 PM
jamo jamo is offline
is there an adapter to go from welder plug to dryer plug?
i have my garage set up with a 220 regular 3 prong, 3 wire outlet. is there a way to go from that to a dryer plug? they are both 220 just different breakers. i have 2 jobs at family members houses and was wondering if i could tap into their dryer plug and change the breaker while i was there rather than messing around with the plugs. is this possible and is there such an adapter. pics would be great if so or an old thread. thanks.
Old 02-09-2010, 10:12 PM
DSW DSW is offline
Re: is there an adapter to go from welder plug to dryer plug?
Search...
http://weldingweb.com/showthread.php...=dryer+adapter
http://weldingweb.com/showthread.php?t=11537
Ronald Reagan
Old 02-09-2010, 11:06 PM
Broccoli1's Avatar
You shouldn't need to change the breaker unless you really need more than 30amps
Dryer should be 30amps.
TA 185
Miller 125c Plasma 120v
O/A set
Old 02-10-2010, 06:53 AM
BD1 BD1 is offline
hi,you could buy a dryer cord with male plug end that matches the wall outlet, a electrical box mount female outlet that matches your male plug, box connector for cord , and mount it to electrical box. you then have dryer plug on cord and your outlet in electrical box.it would be a real short 220 extension cord. Cheapest way to make it.BOB
Old 02-10-2010, 09:36 AM
thank you. i thought that was the way to do it but thought i would check first.
Old 02-10-2010, 03:23 PM
BD1 BD1 is offline
hi, depending on how your machine is wired you could save some money by wiring the dryer cord to your machine .Some machines it will take forever to remove screws to replace cord. hope it works out.
Old 02-10-2010, 07:36 PM
bratkid63's Avatar
bratkid63 bratkid63 is offline
Changing the breaker is not a good idea. The breaker is sized to the wire supplying the receptacle, more than likely #10 for 30 amps. Additionally, the receptacle itself is only designed for 30 amps.If you replace the breaker with a higher value, the wire running through the walls could potentially catch fire before the breaker pops. This is not likely, but I sure wouldn't want to try and explain to the relatives / fire inspector / insurance company why I thought it would be OK to oversize a breaker after the fire.
I would leave the breaker alone, and try the welder with it as is. Chances are you won't be running the machine at it's max setting, so you will probably be drawing less than 30 amps anyhow.
Miller Thunderbolt AC/DC
Miller Dialarc 250HF
Miller MM251
Miller MM200
Miller MM130
Miller Spot Welder
Victor O/A rig
Old 02-10-2010, 10:41 PM
i would leave a 30 amp breaker, but you know how some people like to do their own wiring. i would only change it if it was too big of a breaker. you know how people are with breakers that dont know what they are doing "bigger is better". i am more worried about my welder.
Old 02-14-2010, 12:30 PM
ImagineMW ImagineMW is offline
If your machine is small enough to take to your neighbors house, you probably won't be pulling more than the 30 amps supplied. Also, make the pigtail adapter yourself. Much cheaper.
