Old 12-17-2005, 12:56 AM
lowlypawn lowlypawn is offline
Syncrowave 180 with a spool gun possible???
I have a syncrowave 180 I am very pleased with but I was just curious if it was even possible to use a spool gun with it. It seems like that would be the best of both worlds if possible. Now that I’m getting use to tig I can see how a MIG would be much faster in different situations especially at tacking up projects.
I asked a guy at work who was a welders and he wasn't sure so I figured I would ask here. So dose someone make a spool gun that works with a syncrowave 180? Is their some fundamental difference between tig and mig that makes this impossible?
More details the better and thx in advanced.
Old 12-17-2005, 06:26 AM
chopper5 chopper5 is offline
im going to say no it wont work mig and tig/stick have diferent power one
is CC and the other CV ,im shure one of the other's will explane better i have not yet had any coffiee
chuck
Old 12-17-2005, 02:24 PM
smithboy smithboy is offline
You could run a cc/cv feeder that has spool gun attachment. I use/have used a miller dialarc with a hobart hefty (no gun), but there are some suitcases that have a straight hookup for a gun. Some limitations apply...I think it doesnt give good results for some applications, but.....
So,...short answer, you can...but, it's not the best route for some applications and it might cost a bit more than starting with a CV machine...
Smithboy...
Old 12-17-2005, 09:12 PM
halbritt halbritt is offline
I doubt that a voltage sensing feeder setup for CC would work correctly with a spoolgun, though I could be mistaken.
-Heath
Old 12-17-2005, 10:59 PM
I just looked on the readywelder website. They have a readywelder spoolgun that will hook to a cc welder. About $400 on ebay. That'd be probably the least expensive route. I have used these things before on batteries and they work pretty good...better than I expected, in fact. But they are not as high quality as some of the regular spool guns I have seen.
Smithboy...
