Old 02-17-2010, 01:49 PM
Bluesman Bluesman is offline
3n1 or 4n1
Tig unit is down and dang plasma just died. I need to replace both since these units have been here since before I was in highschool myself. The torch is screwed up on the plasma cutter and the local weld shop says that it would be cheaper to buy a new unit than it would be to replace the torch. The tig unit is a Hobart Power supply that is hooked up to a Lincoln HF, apparantly the HF unit is screwed up.
I need to get some quotes. I have some highschool kids here that are missing out on tig and plasma with these two units being out of order.
If you can, help a brotha out please.
If you don't use your head you may as well have been born with two backends.That ain't exactly how Papa used to say it.
*Linc'n WeldanPower 200 with a Wis. 2 cyl. w/handcrank
*Linc'n AC225
*Linc'n ProMig 180
*tiny porta torch...
Old 02-17-2010, 02:25 PM
longevity-inc.com's Avatar
longevity-inc.com longevity-inc.com is offline
Re: 3n1 or 4n1
Bluesman,
We can take care of you. I am going to send a PM and will consider the fact that you are teaching with the unit. Thanks for considering LONGEVITY.
Let me know if you have any questions. Also, do you need to weld aluminum or will you use DC only on the TIG?
Thanks,
Simon
LONGEVITY Welding
www.longevity-inc.com
Phone: 877-566-4462
JOIN OUR WELDING FORUM. Go to www.freeweldingforum.com
Old 02-17-2010, 02:34 PM
Re: 3n1 or 4n1
Originally Posted by longevity-inc.com View Post
Bluesman,
Thanks,
Simon
We do need aluminum capabilities BUT if that isn't a possibility then we can always get a spoolgun for our Lincoln Power Mig and just mig the aluminum. I've been reading up on Longevity, Everlast and Gianttech and you guys all seem on the up and up when it comes to quality products and tech support. I thought we would give ya'll a shot at a quote since I'm almost certain that one of you will be able to satisfy the needs we have with a single machine cost effectively whereas with Lincoln or Miller we would probably end up getting 2 different pieces of equipment and it would be a small fortune. Ya'll don't happen to do demonstrations for schools when you sell equipment to them do you?
*Linc'n AC225
*Linc'n ProMig 180
Old 02-17-2010, 04:26 PM
Re: 3n1 or 4n1
Bluesman,
If you provide a number via Private Message, we can have a rep contact you and get you a very good offer. We do test all equipment before it leaves here and can offer you a great price, which is what you are hoping for.
I think speaking to each of the mentioned companies will give you a better idea of customer service and knowledge since the machines are similar.
Please let me know how that sounds.
Simon
LONGEVITY Welding
Phone: 877-566-4462
Old 02-17-2010, 04:38 PM
Re: 3n1 or 4n1
Bluesman,
Simon
I appreciate it. I just sent you a pm.
*Linc'n AC225
*Linc'n ProMig 180
Old 02-17-2010, 05:09 PM
Re: 3n1 or 4n1
Scott,
Thanks for taking the call. If you still have questions or concerns, please let us know.
Simon
LONGEVITY Welding
Phone: 877-566-4462
[IMG] code is Off
HTML code is On
