Welding table build
Well I've started to build a welding table for myself. Plan to build it 36 by 48 Inches with 3/8 Inch thick top. Picked up majority of the stuff for the framework and started this weekend on welding up the four legs. I decided that one pair of legs would have adjustable feet so that I could stabilize the table if the floor was slightly uneven since the table will be moveable. Attached are some pictures of the legs and the accompanying welds.
Pic 1 shows the leg with adjuster and you can see the second threaded adjuster bolt laying on the bench behind it. Pic2 shows a sample of the weld inside the leg and Pic 3 shows the weld on the round foot plate at the bottom of the leg. Any critques on the weld are welcome. I am using a MM211AS with .030 wire and 75/25 gas at 20cfh I am using the auto set feature for voltage and wfs setup.
Harold Mulder Miller 211 Autoset HTP 201 Invertig with water cooler Hardinge Cataract Quick Change Lathe |
Re: Welding table build
Looks good so far. Keep the pics coming......
Nctox, Stickmate LX 235AC/160DC HH210
A good insurance policy when welding threaded assemblies is to use anti spatter spray, or anti spatter dip, on the threads. It keeps spatter from messing up the threads.
Thanks for that tip. I use the anti spatter dip on the torch never thought to put it on the threads. That being said the two posts with treads are done and they both thread up and down fine. Luckily most of the rough welding occured away from the threads. More pics will follow however not to quickly as I may not have much time to work on the desk.
Well time to show a few more pictures of the table. First picture shows the legs and the future lower shelf area. Second shot shows the table more or less complete upside down after the leg assembly was welded to the table top assembly. A few more minor things to do while upside down and then we'll set her up on the concret. Next post will include the finished picture shots.
that table is coming along very well. Nice work! Keep posting pictures!
what are the round guide holes for?
The round guide holes are for the contraption that will hold the wheels that I'll use to roll it around. I've almost finished with it on it's back should be flipping it over and will then also include pictures of my wheel assembly if it works.
![]() It might be a while for the final pictures as I am heading off for a few days to visit the folks.
Well I flipped the table over on it's legs and my wheels work like a charm
![]() ![]() I still have a little work left to do cut the expanded metal and install it on the two shelves under the table as well as securing the lower table assembly and then a couple spray bombs to make it look good. First picture shows the wheel assembly when still upside down. One end had fixed wheels the other end had rotating wheels. Second picture on the ground shows the wheel assembly in the down position. The flat bar that is on the vertical is the lever you stand on to lower the cam that pushes the wheels down and raises the table by 1/2inch. The third picture shows the same setup with the table back down and the cam off centre allowing the wheel assembly to come up and the table legs to lower back to the ground. Fourth picture just shows the lower half with the support for the upper and lower shelves. All and all I'm quite happy with it. The wheels work and if the floor was clean it rolls smoothly. The table is 41inchs high which for this 6ft5in fellow seems to work fine.
Looks real good. Do you think the arms to engage/disengage the wheels will be in the way? Seems like you would want it flipped up like that when the wheels are DOWN instead of stowed so you didn't have that piece sticking up getting in your way when you store stuff on the bottom shelf.
True, however the engage/disengage arms line up just inside the overhang of the table and I don't think i'd want much stuff to stick out past this as it would get in the way of working around the table. However only time will tell once I start stuffing stuff on the shelves whether it does get in the way.
Very nice.
Well I thought I might as well post one last picture of the completed table. Everything worked out like I planned only time will tell if the plan was right or if I need to make modifications. Looking forward to working on the first project on this table later this month.
Beautiful work sir. I love the flip-up casters.
Miller 211 w/ spool gun Miller Dynasty 200DX Longevity 60i IGBT plasma O/A w/ crappy chinese torch/gauges South Bend 10K lathe Grizzly 4029 10x54 mill Grizzly 7x12 hor bandsaw angle grnders, bench grnder, bench belt sndr 7.5 hp 80gal cmprsor |
Looks nice.
Nice looking table. I like the casters...
Dan |
Thanks on the compliments
pretty cool idea
Lincoln Pro Core 125 Lincolin sp 100 Miller Big 40 Lincoln WP 225 G7 Lincoln Idealarc SP250 http://www.facebook.com/hdwelding?sk=wall www.handdwelding.com |
