Old 02-22-2010, 06:30 PM
Deadlinetv Deadlinetv is offline
stack of dimes welding
Is this a big secret in welding? I have heard guys that have supposedly weld for their whole lives and they use a certain technique, perhaps a q shaped movement? to get that "stack of dimes" look? Or am I just over complicating this?
Old 02-22-2010, 06:49 PM
Boostinjdm's Avatar
Boostinjdm Boostinjdm is offline
Re: stack of dimes welding
Mig like Tig. Search it....
My name's not Jim....
Syncrowave 200
Millermatic 251 w/bottle mod
Spoolmatic 30A
Maxstar 150s
Cutmaster 81
Jet JTM-1 mill
Jet GH-1340-W3 lathe
Old 02-22-2010, 07:06 PM
David R's Avatar
David R David R is offline
I don't need no stinkin dimes!
It depends on what process you are using. Sometimes the dimes just show up because of the technique I use. If the weld penetrates full and is smooth, of the right size and the toes are tied in like they should be, the surface of the weld doesn't mean much smooth or like dimes.
David
Real world weldin.
Old 02-22-2010, 07:07 PM
weldbead weldbead is offline
a dime is a puddle..distinct and seperate from the one before and the one after.
makethepuddlefeedthepuddlemove...do it again...
that is for oa and tig, i dont do no migweldin...
Old 02-22-2010, 07:28 PM
David
Yea i figured, if the weld holds would be the most important. Getting the right penetration is key... but i guess it could come out smooth either way, so it just depends... thanks for the response.
Old 02-22-2010, 07:35 PM
welderShane's Avatar
welderShane welderShane is offline
David
Well said David
Ya gotta spend money to make money!
Old 02-22-2010, 07:36 PM
woi2ld's Avatar
woi2ld woi2ld is offline
then why r there so few that can do it perfectly.? I know quite a few welders , and only One that does it perfectly..........and he makes a shat load more money than the others.!
but whada i know
shut-up painter
Old 02-22-2010, 08:14 PM
ibanezed4yrs's Avatar
ibanezed4yrs ibanezed4yrs is offline
only time i use the dime technique is on aluminum...
if you're not livin on the edge, you're takin up too much room..
Old 02-22-2010, 11:21 PM
farmersamm's Avatar
Stack of dimes can be a very nice looking weld when working with 6011 or 6010. It's a whipping technique to prevent burnthrough, and stack metal.
MIG is a beautiful process when done right. Wonderful smooth bead. I know there's a new thing out there, people want to stack it, and I guess that's ok, not sure about the effects within the weld, but it's just a matter of aesthetics I guess.
Old 02-22-2010, 11:24 PM
Bozzza's Avatar
Bozzza Bozzza is offline
Cigweld Transmig 265se
Boc 140amp Stick
Boss 200amp AC/DC TIG
Lincoln Electric Invertec V260-S
Old 02-23-2010, 12:29 AM
farmersamm's Avatar
Still don't know whether the OP is talking about iron or aluminum, TIG, stick, or MIG?
Old 02-23-2010, 09:21 AM
ZTFab's Avatar
ZTFab ZTFab is offline
There's nothing "new" about stacking dimes.
Maybe it's new to you but it's not to many others.
Hold my beer...watch this.
Old 02-23-2010, 10:59 AM
Metarinka Metarinka is offline
the so called "stack of dimes" is when the puddle happens to freeze just fast enough to show individual ripples of where filler was added. Perfect technique will not always develop a bead that has the "stack of dimes" effect and you can have the look and have a very defective weld. Like wise when we do fused root on TIG there's no bead at all just one continuous bead with an overlapped start.
It's really just consistancy. getting a very even bead width, travel speed and filler dabbing technique. If I cup walk I can get the bead every time with TIG, but I generally turn up my heat and increase my travel speed which usually destroys the chance, but increases my productivity.
Old 02-23-2010, 08:05 PM
Very sorry, I completely forgot to mention I was asking about Iron, with a MIG welder.
But I enjoyed the posts, even the one on TIG, loved the video.
Metarinka - Obviously it is important to get welds done in a timely manner. I guess the whole stack of dimes beautification is fine when your on your own time....
Old 02-23-2010, 10:07 PM
Grimm1's Avatar
Grimm1 Grimm1 is offline
I usually only try for stack of dimes when I know the weld will be visible. If it's getting burried under umpteen coats of paint, or powder coat I don't bother. Stack of dimes is asthectically pleasing. It also gives the impression that the weldor really knows what s/he's doing, demonstrates how much control they have over the puddle.Though as mentioned befor, you can make beautiful welds that aren't worth slag. Focus on weld integrity first, asthetics will come later.
