Old 02-24-2010, 02:00 AM
Brett's Avatar
Brett Brett is offline
A couple of Coffee tables
A couple of Coffee tables that are proving popular.
A good guess is better than a bad measurement
Old 02-24-2010, 02:01 AM
Brett's Avatar
Re: A couple of Coffee tables
Ok that didnt work...
Old 02-24-2010, 02:07 AM
Brett's Avatar
The "C" types are for going over an arm of a sofa for your ciggies or drinks, you can also eat off them.They are 12mm solid, powder coated "Jasper" with "Latte" painted 6mm toughened opti white glass (A a low fe glass that is very clear and no green tinge)
The spider is a Octogon 10mm toughened glass, 30mm bevel, painted black , 12mm and 10mm solid mild steel, powder coated black done with a 415V PT 185 with 100 % Ar
Old 02-24-2010, 02:24 AM
SpyGuy's Avatar
SpyGuy SpyGuy is offline
Nice work on all of them. I like that octogon table, good finish.
How are you attaching the glass tops? Doing the frames, then screwing them together from the underside?
Old 02-24-2010, 02:41 AM
Brett's Avatar
No it just sits there, so people can remove and clean them.
The big one has 8 rubber self adhesive blobs and it doesn't move at all , the few I did before that I silicone on 4 blocks so it couldn't slide off but I found it unneeded.
Brett's Avatar
The C types are located by the frame
Old 02-24-2010, 09:23 AM
Jimmy_pop's Avatar
Jimmy_pop Jimmy_pop is offline
that's awesome! While its not my desgin style, ive been building furniture for 5 years now and will go full time this year having replaced my full time jobs income. I wish you the best ... designing and building is soo much fun.
Old 02-24-2010, 09:32 AM
ed mac ed mac is online now
nice work
Old 02-25-2010, 01:56 AM
SpyGuy's Avatar
The big one has 8 rubber self adhesive blobs and it doesn't move at all , the few I did before that I silicone on 4 blocks so it couldn't slide off but I found it unneeded. ... The C types are located by the frame
Okay, thanks. I know a few people have built tables, and around the top outer edge of the glass, they've put on a cap piece that makes sure the tabletop stays put..
