Can anyone tell me what this symbol is on my welder
Hi there, Im just wondering what this symbol is on the back of my welder above a small hole. (sorry bad picture) Im not too familiar with electrical symbols, usually its pretty obvious but this one I cant figure out.
Re: Can anyone tell me what this symbol is on my welder
I believe that's a ground symbol for an electrical hookup.
“There’s class warfare, all right, but it’s my class, the rich class, that’s making war, and we’re winning.” Warren Buffett American by birth, Union by choice! Boilermakers # 60 America is a Union. |
yup..... that's a ground symbol
Synchowave 180SD Bernard 3500SS water cooler Millermatic 200 Parker Plasma Tec 40dv Operating Engineers Local 12 |
i think the upside down christmas tree is ground. pretty sure. final answer
shut-up painter |
Earth ground
If you cannot convince them, confuse them. Harry S Truman |
Great, thank you. So I guess if I may be working in a moist area or somewhere where there may be risk of shock I should hook up a ground wire?
I would think that it is already grounded through the power plug; the round pin on the plug should be connected to the metal case of the welder. Check for continuity with a multi meter, case to ground pin on the plug?
alien prison tatoo....
the machine should be chassis grounded through the power cord...usually a green wire... |
Your right it is already grounded with the power cord I should have realized that. Whats the point of the extra grounding hole/attachement then? Perhaps if the power source doesnt have a built in ground?
That is a high frequency ground if it is a tig welder. It should be grounded separately to an outside ground rod.
Welders: Esab Migmaster 250 Penncraft 230 (oldy but goody) HF Plasma 30 (Italian) Lincoln Ranger 8 Smith Oxy/Acetylene/Propane Lincoln SA200 Everlast Power Tig 250 EX Everlast PowerUltra 205 |
or to your typical in-home ground, like the plumbing?
That's the level you're supposed to submerge the unit in water up to.
We want to see something like this in the signature line: Lincoln Ranger 250 Miller Auto-Darkening Elite Helmet Lincoln 100 Lincoln Mig Miller Spectrum 375 Craftsman 8 galllon gas powered compressor Longevity 200amp Tig Welder LT-200D |
I always thought it was for an earth ground. On some jobsites I thought they make you bury a rod and you have to connect it to there to ground the machine. I am pretty sure my Honda generators have them also.
"Stick-man is wise" - Farmall "Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550 "StickyFingers-man" Commander 500D, LN25 Shopmaster 300, Super S-32P Hypertherm Pmax 600 Smith & Oxweld O/P |
It is definitely a ground symbol though. And no, not plumbing.
"SOUTHPAW" A wise person learns from another persons mistakes; A smart person learns from their own mistakes; But, a stupid person.............never learns. |
You know full well that the symbol indicates the level the inside should be filled up to. |
