Old 03-07-2010, 01:41 PM
Rob Garner's Avatar
Rob Garner Rob Garner is offline
Small tubing and flat stock roller... free plans included
To start off, this is not my design. I found it here http://www.tbucketeers.com/topic/693...e-tube-bender/ and modified it to use what I had at hand.
Plans are here in pdf format: http://www.mediafire.com/?oxz1y2mojdz
This has been and still is an ongoing project. The only thing left to do is to finish all of the dies I want to make. Those would be round tube sizes 1/2"-1", square tube sizes 1/2"- 1", flat stock the hard way sizes 1/8", 3/16", and 1/4" and a set for flat stock up to 1 1/2" wide the easy way.
To start off, all material is 1018 cold rolled steel except the bronze bushings. The drive sprockets and chain were purchased from Farm and Fleet. They are 12 tooth for #35 roller chain iirc.
The rolls can be up to 3" in diameter by 1 1/2" wide.
continued...
Darwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Old 03-07-2010, 01:51 PM
Rob Garner's Avatar
Re: Small tubing and flat stock roller... free plans included
Here is a sample of what the plans look like.
