Old 03-15-2010, 10:00 AM
darryl3 darryl3 is offline
Welding to I-Beam
Newbie Question I cant find anywhere here.
Looking to weld some angle to the flat face of an I-beam. The load would be minimual 100#, and little moment on the beam, but some concerns over code, due to the fact that the I-beam supports the roof. Any restrictions on welding to structural beam?
Thanks,
Old 03-15-2010, 11:02 AM
raferguson's Avatar
raferguson raferguson is offline
Re: Welding to I-Beam
The restriction that I always remember is never to weld across the face of the I-beam, due to the risk of forming cracks at a high stress point. If you run a bead on the edge of the face, that is less likely to form a crack, minimizes the stress raiser.
Obviously many things are just clamped to the I-beam. An angle iron could have one clamp on each side, especially if the weight involved is not a lot.
Richard
Sculptures in copper and other metals
http://www.fergusonsculpture.com
Syncrowave 200
Lincoln Weldpack 175 HD - MIG
Readywelder spoolgun
Hypertherm 600 plasma cutter
Thermal Arc GMS300
Victor OA torch
Homemade Blacksmith propane forge
