Old 03-20-2010, 07:41 PM
llamafur's Avatar
llamafur llamafur is offline
Oxygen Acetylene cart
I built this cart with some angle iron, its welded with 3/32 6013 DCEP @ 120 amps.
I also upgrade to a bigger Oxygen tank!
I'm a Hoss, and a Boss.
Old 03-20-2010, 08:57 PM
mla2ofus mla2ofus is offline
Re: Oxygen Acetylene cart
Nice build, looks stout. I would certainly attach a chain to the upright to hold the oxy tank. The snubber is pretty poor insurance against the oxy tank falling over and breaking the valve off. Trust me, you don't want a rocket runnin' loose in the shop.
JMHO,
Mike
Ol' Stonebreaker
Miller 175 mig
Victor O/A setup
Makita chop saw
Old 03-20-2010, 10:59 PM
llamafur's Avatar
Yeah, I couldn't find a chain or belt at the time. I figured a bungee cord is better than nothing at the moment. I'll be getting belts for both tanks.
Old 03-21-2010, 01:40 AM
tanglediver's Avatar
tanglediver tanglediver is offline
A nylon web belt is better than rubber, chain is better still. The cart looks good, how does it handle?
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 03-21-2010, 09:54 AM
llamafur's Avatar
Pretty well actually. I think I may need some better wheels.
Old 03-21-2010, 05:05 PM
Some taller wheels would probably help, try scrounging some rear wheels off a high wheel lawn mower and mount them closer to the back of the cart frame.Just a suggestion, cut the spacer out from under the front and then mount the tall wheels so they are not quite touching the floor when the cart is upright. With the tall wheels when you tip it back to roll it the bottom of the cart will have plenty of ground clearance. I found two 16" solid rubber bicycle style wheels for mine and they roll easy over any type of ground.
As I said, just a suggestion,
Mike
Ol' Stonebreaker
Miller 175 mig
Victor O/A setup
Makita chop saw
Old 03-21-2010, 05:53 PM
llamafur's Avatar
I don't think that would work for this. I put the wheels back further because the cart seemed a little bit too easy to tip. Then again the cart is staying in the shop, no bumpy ground there.
Old 03-21-2010, 06:49 PM
Aquafire's Avatar
Aquafire Aquafire is offline
Is that a wooden platform in the bottom? If it were me, I'd replace it with metal to thwart the Murphy's-Law-fire that could occur.
Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Old 03-21-2010, 07:02 PM
llamafur's Avatar
Yes it is wood. I do all my cutting and welding outside. I just run the cables and hoses through the door. The garage is far too messy (Thanks mom!) My "half" is clean by the way.
