Prev Previous Post   Next Post Next
Old 03-24-2010, 03:37 PM
madkaw284 madkaw284 is offline
Everlast 250 EX and W200 water cooler questions
I have recently purchased (The machine should be in sometime this week) an everlast 250EX and the W200 water cooler and noticed that the connections are all different from the standard water cooled torch setup. I have some other torches (Weldcraft) that I would like to utilize on the machine from time to time depending on the job but I dont want to cut the ends off of my old torches and change them to fit the 250EX. My weldcraft torches have the 1/2" Dinse power connection (Witch will work) but the gas line is a 5/8"-18 male RH thread and the water lines are 5/8"-18 males (water in line is RH thread and the return line is LH thread). The W200 water cooler comes with 5/8" male tread connections on the unit both RH threads and I'm not sure what type of connection is on the power unit for the gas line. What I would like to do is convert everything on the machines to fit this style of torch setup and convert the that comes with the unit this way to. So my question is has anyone else run into this issue and if so what did you do? Thanks
[IMG] code is Off
HTML code is On
