Old 03-27-2010, 02:22 PM
zopi zopi is offline
cracked diesel head.
I have a 3 cyl kubota diesel with a crack in the center cylinder of the head..appears to be a surface crack, I am certainly not capable of welding it...does anyone know of a shop in eastern virginia that can do an oven weld repair on something like this, in addition to giving it a stock valve job after?
I would just buy a new head, but 700 bucks per, I don't have the cash to sink into what is basically a free skid steer...
Lincoln Weldpak 100
Miller Maxstar 150
Cutmaster 82
Victor OA torch set...somewhere around here...
Old 03-27-2010, 04:33 PM
papabear's Avatar
papabear papabear is offline
Re: cracked diesel head.
Even if you have to pay $1000. to get it fixed,............
A $1000. skid steer is a good deal.
"SOUTHPAW"
A wise person learns from another persons mistakes;
A smart person learns from their own mistakes;
But, a stupid person.............never learns.
Old 03-27-2010, 05:18 PM
true....but I don' got right now...<G>
Lincoln Weldpak 100
Miller Maxstar 150
Cutmaster 82
Old 03-27-2010, 08:53 PM
castweld castweld is offline
I usually charge 400 to repair with valve job, pressure test, and surface. Most of the production welding shops charge more.
I have been quoted 900-1200 from local dealers for new heads. May be higher here? For 700 (if it is NEW) I would get a new one, swap parts from old head. They come bare. Try to determine cause of overheating and repair problem too.
Peter
Old 03-27-2010, 09:04 PM
Peter
400 ain't bad...I'll likely wind up getting a bare casting...spensive bloody little things.
HEH...cause of overheating is easy..piece of rebar through the radiator...
I love old equipment, and I keep telling myself that.
Lincoln Weldpak 100
Miller Maxstar 150
Cutmaster 82
Old 03-27-2010, 09:12 PM
jasonstewart jasonstewart is offline
rebar through the radiator. nice
Old 03-28-2010, 03:17 PM
Rhyno's Avatar
Rhyno Rhyno is offline
Peter
Great advice! That is how I would do it.
I have repaired heads, depending on where the crack is, makes some "hit and miss."
-Rhyno
07 Fowler 200D
65 RedFace
04 Miller TB 302, 22hp
Miller 12RC
Miller HF 251-1
Lincoln SP135
HyperTherm PM 380
and a few others...
Originally Posted by Rhyno View Post
But, if I "all of a sudden disappear.... ...." hopefully I didn't suffer too much....
Old 03-28-2010, 04:15 PM
tresi's Avatar
tresi tresi is offline
I find that they work better without rebar or in the case of my last radiator job they should not be able to flop back into the fan.
Tough as nails and damn near as smart
Old 03-30-2010, 09:42 PM
Ok...so..this thing will cost 700-900 bucks either way..unless I get lucky and find a salvage engine, or get creative and adapt something..right..
I'm gonna strip this head down, hot tank it, grind out this crack, put up a little furnace, preheat and weld the damn crack...it appears fairly shallow, and isn't in a wierd place...got not much to lose here...gotta guy at work will true the gasket surface for me and pressure test...might have to go get a valve job...or might check and see if the local high school had a valve machine..god knows I did alot of free valve work when I was in high school...
This ought to be fun...
Lincoln Weldpak 100
Miller Maxstar 150
Cutmaster 82
Old 03-31-2010, 12:08 AM
76GMC1500 76GMC1500 is offline
Have you heard of stitching pins. These may be a DIY alternative, especially if the crack doesn't run across an injector seat or a valve seat. I would do a dye penetrant test to determine the full extent of the crack before continuing with any method.
Old 03-31-2010, 09:51 PM
If you are planning to arc weld it- don't. Even if it would pass a pressure test it will fail once you run it.
Two welding options that will work
1: fusion with cast iron filler, OA torch
2: spray weld with OA rig
This can be done "back yard style" but isn't easy.
Your crack probably isn't just surface, but a pressure test will show if it goes through. If you want to attempt this, mag the head and post a few pics. If you want some advise I'd be happy to help. If you are the kind that likes to "figger it out" on your own, have some fun and be sure to post results.
Peter
