Old 04-28-2010, 03:44 PM
killdozerd11's Avatar
killdozerd11 killdozerd11 is offline
It got here yesterday
My Trail Blazer 302 Air Pak
Suitecase 12rc
625 Extreme
50 ft controller cable
Took my rusty piece of junk and my friend in the pic and picked it all up
ran it and discovered one air feedback tube was not connected to the controller hooked that up runs great lots of air no oil leaks or other problems so far
It has it all...... i just ordered the condenser/separator option
Now i have to plumb the air outlet and make up cables
I got 100' of 2/0 cable to make my extended leads....2- 50 footers
and 25' of 0/1 for short ground 10 foot and stinger lead 15 foot
Now i need some advice
I want to use quick connectors for lead changes i don't want to go over the tweco vs dense
debate but i want your advice
I am thinking about replacing the standard lug connectors on the front panel with quick connector terminals
Either the Radnor F panel socket # BE3570 or the Tweco F panel # 114TSF
The Radnor's are cheaper and an international standard so they say
The Twecos are very popular in the industry
And adapters are available to go to either style in case i need to use cables with the other type connectors
I will Thank You for the advice before hand
What would SATAN do ??
Miller Digital Elite
Miller Trail Blazer 302 Air Pak
Suitecase 12RC
Spectrum 625 Xtreme
Victor O/A
Evolution Rage 3 saw
Rusty old Truck
Old 04-28-2010, 03:49 PM
jamlit's Avatar
jamlit jamlit is offline
Re: It got here yesterday
That is one nice looking machine
Congrats
Miller DVI2
Lincoln Precision Tig 225
Thermodynamics Cutmaster 38
Everything else needed.
Old 04-28-2010, 07:22 PM
DesertRider33's Avatar
Now that's the good stuff!
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 04-30-2010, 02:58 PM
I put the tweco -lug to tweco 45 degree adapters on and the covers locked back into place when done ...looks nice and sanitary
Got the 1/2 in copper pipe to make the saddles for the connections
Getting antsy i want to weld with it now....but got other things taking priority right now
Suitecase 12RC
Spectrum 625 Xtreme
Victor O/A
Rusty old Truck
Old 04-30-2010, 04:26 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is online now
Use something that makes your stuff unique so no one wants to borrow your leads and forget to return them.
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Old 04-30-2010, 05:27 PM
Like winding the leads around a claymore
Not subtle but effective
Suitecase 12RC
Spectrum 625 Xtreme
Victor O/A
Rusty old Truck
Old 04-30-2010, 07:13 PM
farmersamm's Avatar
Try puting that baby on the azz end of a modern day sissy 1/2 ton, and see what happens
That old Chev is a beaut
Old 04-30-2010, 09:17 PM
ed mac ed mac is offline
nice but i cant see spending $4000.00 on a air comp.
the comp. will last 30,000 hrs so your going to have to
rebuild the the engine 8 to 10 times before the comp
needs work by then will miller go to a new engine co.
like they did with onan to kohler then what
i rather go with a low rpm diesel like the pro 300
that will go 30,000 hrs and a quincy gas comp
that will go 50,000 hrs for the same money
Old 04-30-2010, 09:37 PM
My choice was the Kubota diesel option on the Trail Blazer but the don't offer that with the air pak
why i do not know
Because the old Air n Power that a friend of mine had was basically the same just BIGGER
Suitecase 12RC
Spectrum 625 Xtreme
Victor O/A
Rusty old Truck
Old 04-30-2010, 09:56 PM
Matt_Maguire's Avatar
Matt_Maguire Matt_Maguire is offline
why i do not know
Nice Rig;
Just buy the rebuild parts now as you can (cause when you have them... you don't seem to need them as often).
After your'e gone let somebody else sort out all the rest you had "just in case".
Matt
Oh Yea, Nice Rig! Break it in, change to synthetic, treat it like a beautiful child and run it for over 16,000hrs (1984 Briggs twin still going, different but hard use). Ya just do the best with what you got, it's OK.
Old 04-30-2010, 10:00 PM
i dont think they offer the diesel on the air pak
because it would cost over $13,000
and i think a diesel engine that runs at
3600 rpm it a waste the hole idea of a d engine
is low rmp that why they last longer than gas
a good d engine will run from 1800 to 2200
rpm and will do it all day long
(not a good diesel a real diesel)
Old 04-30-2010, 10:35 PM
six six is offline
Well done! I have been looking at compressors with the same cfm and psi and it will cost atleast $2500 for the engine/compressor which weighs 550lbs. I am very close to following suite. If you are still working the machine after 10,000 hrs business should be good, stashed some money away and time to upgrade/rebuild anyway. Congrats and up date us on the trial... CAG... see how the air blows.
