Can I tack with TIG, then weld with MIG?
Folks, I bought a new exhaust system for my car, but I have to modify the positioning of the air tube for the catalytic converters (the tube was MIG welded from the factory). I have cut the tube off, modified it to fit as required, and ground away the MIG welding from both pieces (the air tube, and the tube to which it is welded).
I want to tack the tube to it's new location, then take it to get MIG welded back together (I don't have a MIG welder, I just have a TIG welder, but I do not want to TIG it back together). Can I tack the tube in place with my TIG welder (I have ER70S2 rod), then have it MIG welded (over top of the TIG tack welding too)? Thanks.
Working on cars and bikes is my hobby, learning to weld the pieces together is my quest. Lincoln V205-T AC/DC Lincoln MIG 180C JD2 Bender JD2 Notcher Myford ML7 Lathe Bend Brake Tungsten Grinder Drill Press Understanding Wife |
Re: Can I tack with TIG, then weld with MIG?
Sure. The question that is usually asked is the other way around but no problem MIG welding over a TIG tack.
Just curious, why don't you care to TIG weld the whole thing?
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
>>Just curious, why don't you care to TIG weld the whole thing?<<
Duane, thanks for the response, I appreciate it. My TIG skills are not sufficient to weld this puppy, but I can sure do a mean tack. Regards, thanks again.
