Old 05-25-2010, 09:10 AM
DageonYar DageonYar is offline
Need to MIG weld galv... Help?
I need to MIG weld some galv steel nuts to some mild steel (to be used as levelers on table legs), and I'm all paranoid from reading all the horror stories about welding galv. How should I do this while keeping safe?
Old 05-25-2010, 10:01 AM
MoonRise's Avatar
MoonRise MoonRise is offline
Re: Need to MIG weld galv... Help?
Do a 'Clinton'.
No, no, not -that- Clinton with the intern under/on the desk and the cigar.
The Clinton move of "Do Not Inhale".
More seriously, there are two aspects involved here. One is the effect of the zinc on the weld and the other is the effect of the zinc on you.
For the first aspect (zinc in the weld), you can use a process that 'tolerates' crud better. Those processes usually involved flux, so SMAW or FCAW usually can tolerate crud better than say GMAW or GTAW (which really doesn't tolerate much crud at all!). Or you can remove the small amount of zinc coating via mechanical or chemical means. A quick hit with a grinder or abrasive of some sort usually very quickly removes the thin zinc coating. Or a dunk in some strong acid like muriatic (aka 'pool') acid.
WARNING : Strong acids and their fumes can be dangerous and damaging to personnel and equipment !! Safety first!
For the aspect of the zinc and you, that is where the Clinton maneuver (no, not -that- one with the cigar, I already told you about that! ) of Do-Not-Inhale comes into play.
But you really shouldn't be inhaling welding fumes to begin with. Small draft or a fume extractor set-up is usually plenty and keep your head out of the welding fumes.
That, and you can also wear an air filter. Not a 'dust' mask, but a "real" air filter. I think 3M has some filters rated for metal fumes/particles.
If this is for a business, PPE or fume control is almost always a requirement. For 'personal' use, PPE and/or fume control and being careful is also a GoodThing.
Old 05-25-2010, 10:45 AM
DesertRider33's Avatar
Take the project outdoors. Wear a respirator mask (3M makes one that most welding shops sell for not much money and uses pink filters). Stay on the up-wind side of the weld and keep your head out of the smoke. You will be fine.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 05-25-2010, 11:23 AM
Wow, great tips, thank you!! <goes rooting around for a cigar>.. no, wait, that's not right... I'll switch over my setup to FCAW and roll the project outside. Would a mask like this one http://www.princessauto.com/safety/b...r?keyword=mask work for this purpose?
Old 05-25-2010, 12:45 PM
bert the welder's Avatar
bert the welder bert the welder is offline
It's getting the right filters that is crucial. ( and a good fitting mask!!!). I haven't got mine on hand, but go to your LWS or safety supply house and they will know which filters are correct. Or, go to 3M's website and they will list them there. North is also a good company. I prefer what is called a "welders backpack". It's a mask with tubes coming out of the mask. The tubes go over your shoulders and down your back. The filters are at the ends of the tubes. Keeps the filters out of the fume cloud and they get less dirty and last longer.
Old 05-25-2010, 12:51 PM
scroll down for the back pack
http://www.westernsafety.com/north20...hres09pg5.html
Old 05-25-2010, 01:06 PM
turk's Avatar
turk turk is online now
good advice
Dynasty 200DX
Passport plus w/ spoolmate 100
victor 315c oxy/(act and prop)
Miller digital elite
milwaukee power tools
Old 05-25-2010, 07:39 PM
DSW DSW is offline
Moderator
The other option would be to get non galvy nuts. While they are not available at home stores, with a bit of searching they are easy to locate. Fastenal, Graingers, MSC and other specialty suppliers carry them. Often the nuts used to hold down parts for mills and so on are non galvy, so look and see if you've got a machine tool supplier in your area as an option. Another option is Stainless. These can be found in many box stores in various sizes.
Ronald Reagan
Old 05-25-2010, 07:48 PM
old mate's Avatar
old mate old mate is offline
Location: mine sites mostly and workshops of varying notoriety
put your nuts in a vise and grind the galv off them, every second flat, and weld the three shiny flats,to minimise shrinkage, run a tap through them when they have cooled down and put some anti-sieze goo in them before you screw the threads in.
Old 05-25-2010, 09:57 PM
Originally Posted by old mate View Post
put your nuts in a vise and grind......
...careful now.......
Old 05-25-2010, 10:57 PM
76GMC1500 76GMC1500 is online now
Just do it, everything will be fine. If it's not fine, so what, you burned up a $.10 nut.
Old 05-26-2010, 08:56 AM
LMAO... well... There's some advice I didn't see coming lol
Old 05-26-2010, 01:23 PM
Jack Olsen's Avatar
Jack Olsen Jack Olsen is offline
Get the 3m masks -- they're $15 and they'll fit under your welding helmet. Get the welding fume specific filters. They're also cheap and they last a long time.
Wear them whenever you weld and the air circulation isn't great.
Old 05-27-2010, 12:20 AM
Sandy Sandy is offline
Of course I'll get branded as being unsafe here but if you're buying your so-called galvanized nuts and bolts from the "zinc coated" section at the typical hardware store there's not enough zinc on a box of a hundred nuts to make the mouse in the corner sick if he inhaled every puff of smoke off the entire box. Those are plated and they measure that in the 10/thousanths of an inch. Like about .0005 or less. They've got that coating down to a science. If they could accurately get less on there they would.
The term galvanized gets used for anything they've waved the word zinc over anymore.
Old 05-27-2010, 12:37 AM
TEK TEK is offline
I agree with Sandy...You could weld 500 of them galvy nuts on and it wont hurt you one bit...
Hold your breath for a second, weld,turn your head away from the smoke, breathe, repeat...so simple even a weldor can do it...
When you weld galvy plated objects, you can tell the difference in the color of the smoke...it is a more blueish color and has white tendrils of coalesced smoke in it....dont breathe that
Old 05-27-2010, 12:52 PM
Funny, that's what you get when you weld on the nuts from the "Zinc Coated" section at H.D.
Hmmmm......
Just sayin'
Old 05-29-2010, 09:33 AM
millrat millrat is offline
Just because the respirator is on your face - doesn't mean it "fits". Clean shaven and check it for leaks!
Old 05-29-2010, 10:58 AM
Rojodiablo's Avatar
Rojodiablo Rojodiablo is offline
My respirator and my girl have something in common....... Wow, this thread went into the gutter!!
I agree with the above sentiments, there is not much to sweat with a zinc nut. Just lightly grind, and go for it, or just burn right through it. For HD galv, grind it off, and go to town.
Old 05-30-2010, 08:53 AM
Tony Mo Tony Mo is offline
Isn't this what you would call a HILLARY Clinton?
