ATV Walking Trailer ( 3D model )
I want to eventually make a Walking Trailer to pull behind my ATV like the ones previously displayed on this forum.
I decided to model one in 3D first to figure out the lengths, different options i could think up, extra accessories .. etc I was curious to know if anyone thinks this is Over / Under Engineered. Safety is #1 of course and constructive criticism would be greatly appreciated. The model is not finished, I still want to model - Tie down locations - Gas can holder - Walls And not sure what i should use for the walls, expanded metal? wood? I was wondering if anyone had more ideas? Again, constructive criticism is greatly appreciated and wanted, so feel free to make a comment Ty for viewing 1. ![]() ---------------------------- 2. ![]() ---------------------------- 3. ![]() ---------------------------- 4. ![]() ---------------------------- 5. ![]() ---------------------------- 6. ![]() ---------------------------- 7. ![]() ---------------------------- 8. ![]() ---------------------------- 9. ![]() ---------------------------- 10. ![]() ---------------------------- |
Re: ATV Walking Trailer ( 3D model )
11.
![]() ---------------------------- 12. ![]() ---------------------------- |
Interesting setup for the wheels, I like it. Makes for easy dumping if needed.
Millermatic 252 Thermal Dynamics Plasma Cutter Dillon Mk 5 OA setup HF Tig/Arc Machine |
Looks great, I may have missed it but what size material are you going to use for the trailer? I see the weakest link of your design being the area where your axle goes into the trailer frame, thus I think i would oversize the axle diameter and the pipe that they are inserted into. Looks like you got a real good design and cant wait to see it done. Thanks, Nick
Nick |
Looks pretty good. Just curious, why the walking tandem for an ATV trailer?
http://weldingweb.com/showthread.php?t=35815 Quote:
2x2x1/8 angle 1x1x1/8 square tube for the height 2x3x1/8 tube for the walking beam Modeled to scale for 6 feet long 2 feet high Haven't decided what to use for the axle/pipe yet any opinions about expanded metal for the sides? or wood bolted on ... or i think i may tweak the design a little so sides are not totally needed Last edited by then3wguy; 05-31-2010 at 10:11 AM. |
"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt |
I like this design but I'd wonder if the tubing that holds the hitch assembly wouldn't be overly-stressed if it got shock loaded. ie: the weight of the loaded trailer bending the tubing just in front of the basket. You may consider gusseting that tube so it won"t bend very easily. An ATV will see many up/down transitions that would vertically stress on that tube. I've bent one this way and it wasn't fun. For all I know the tubing is plenty strong but this may be something to consider.
That is going to be a heavy one. Expanded looks great, but you will dent it up pretty easily.
Common sense in an uncommon degree is what the world calls wisdom. |
I would think you'd want to consider adding gussets to the frame for your wheels on the underside, opposite where you bevel cut the tubing. That 90° attachment looks like it might be a weak spot when you start running into logs or other obstacles with your cart.
![]() (original post by JDH239) http://weldingweb.com/showthread.php?t=41977 And Thank you for all the comments and much appreciated. I think im going to re-evaluate the layout with these comments in mind Ty, more ideas are welcomed |
(that is my cargo carrier with the gusseting). I feel honored you would use my pic as an example.
The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man" Moses 1:39 Link: My name is John, and I am a Mormon. I know it. I live it. I love it! -- ColdCreekWorks.com -- |
This is the trailer I built.
Length - 1.9m Width - 1.2m Upper body height 0.6m Independent walking beam axle (picture of the axle is on the other atv trailer axle post) Electric Tipper with 2 stage ram powered by 220 bar hydraulic pump, controlled by rocker switch on the ATV or remote handheld rocker switch. The sides can all be removed and turned into a normal low sided trailer or a flat deck trailer. It looks heavy and is a bit alright, but have tested it on rough terrain with a full load on it. Will post more photos of it when I get a chance. |
very nice.................good job.
Nice modeling, I've decided to build a walking beam axle for my atv trailer also. After seeing so many and thinking about the terrain I will be going over it will be best suited for my needs.
Brett B & B Fabrication and Welding Inc. Spalding, MI.
What did you use to make those 3D images. I want to whip up my trailer idea as well.
I've been lurking the better part of 6 months. I've picked up a wealth of info from you guys.
Now I have a question. I was building the walking beam trailer in the drawings(with some minor mods to better suit my needs).Everything was going fine right up the the wheel selection. I got a set of wheels/tires at Tractor supply that I thought would work. Turns out I'm not happy with them. No big deal. I was able to pick up a full set of wheels and tires for a polaris sportsman really cheap. I couldn't pass them up they were so cheap. Now the problem...I'm going to scrap the walking axle for now and just use the fronts from the polaris. How do I make the polaris wheels fit any of theoff the shelf hub/spindle sets or even a complete axle? I was thinking of maybe a doughnut shaped adapter plate. Put 4 holes to match the 6" 4 bolt pattern of the wheel and then 1 large hole in the center to allow for the hub center and 4 holes to allow for the hub bolt pattern. Maybe something in 3/8 steel. How far off am I? I'll listen to any reasonable advise. Fire away and thanks in advance. |
#19
I know a guy who built a few of these things, He puts this gooseneck type hitch on it so you dont lose ground clearance around the draw bar. Really nice for going through the woods if you have fallen trees around.
#20
Tandems ride so well!
I had a tiny truck once that used a torsion bar for the rear suspension. It worked - much to my amazement. I wonder if you could use either one or two (for independent suspension) torsion bars as axles (or attached otherways) to allow the walking beam to transfer the weight to the rear axle when the front dips into a hole. On the other hand you can get 4 torsion axles but for a cost and I don't see how those would let the two axles on the same side transfer weight. I'm sure you'll have a grand time making a trailer that does just what you want. It is neat that since you've modeled the design on something other than a napkin that you can share and discuss it with the board and sift through all the opinions to integrate the ones that appeal to you. I really should take the time to learn Google's Sketch Up(free) or SolidWorks ($) but everything comes down to seat time.
Miller Syncrowave 180SD Lincoln WeldPak 100 with gas Handheld Milwaukee Bandsaw O/A Cutting Torch |
#21
Picture #8 displays the shaft attaching the bar that the tires are attached to. How is that shaft secured in / on the base of the trailer. Does this have a bearing or bushing in there?
#22
From the post on this thread and the original, it appears to be done in a couple different ways. some just use DOM tube in DOM tube with a solid rod inside the inner tube. They add a grease zirk to allow for lubrication and debri prevention.
Others use trailer spindles, bearings, etc. Budget is always a factor. but if you read the posts noone has said that the DOM way is bad. just simpler. KISS is a theory to live by if you ask me. saves $ and less to go wrong.
There are no problems. There are only solutions. It's your duty to determine the right one. Hobart Handler 210 Airco 225 Amp MSM Stinger |
#23
Bumping this thread as I'm looking to start buying materials for my ATV trailer.
The SketchUp drawings above indicate angle iron. I have more than enough old bedframe angle but I guess the consensus is that it may be too brittle for dynamic loads??? I also priced some components at Princess Auto (I guess Canada's version of Harbour Freight) The 18.5" trailer turf tire assemblies I want to use are $114.99 each (there'd be four needed). The stub axles are $79.99 each (also x 4). So, before we even start on the steel or any other hardware, with tax in, we're at $881.30. I may consider just doing a Red River cart style ATV trailer, two hubs, two large diameter ATV tires and call it a day. That would run me $519.73 before buying steel.
"These instructions are at our present level of knowledge. Legal requirements do not exist. Technical issues subject to change." _________________________________________ Lincoln MIG PAK 180 Lincoln AC-225 |
#24
I would look into the ones with sealed bearings already. that way all you need to do is get solid rod for the axle. you'll save yourself $300 easily. Post a link for the tires/wheel combo you're looking at.
I did a quick google search for trailer axle hubs and found many online suppliers of spindles in the $20-$30 range. thats some savings right there. I also found this http://goodoutdoors.theshoppe.com/tires_and_axles.html. It's a reduction in cost from what you've got if either way you go.
#25
I also found this. http://www.northerntool.com/shop/too...bber-_-Grounds Maintenance>Lawn + Garden Utility Trailers-_-250820
law of superior tunage, you'll never be able to buy everything for 1 trailer and get it for less than it would cost to buy one. simply because he who can buy more tonage, pays less. Personally, I'd probably buy that one and modify it to do what you want it to. you'll save money in the long run.
