Old 06-06-2010, 05:17 PM
200mphbusa 200mphbusa is offline
Location: SE Washington State--Wine Country TriCities Area
Yes...Another Welding Bench...Oh My God!
I didn't think I would ever be doing one of these posts, but I'm on a TDY for a year and couldn't live without a bench to work on. I also have wanted for the longest time a nice plate to work on, so I bit the big one and had my local steel yard plasma cut 3/8" plate which is dead flat and square corners. Still have to attach a few power boxes (quad receptacles). I am also going to drill and tap a series of holes in the top for hold down clamps.
Bench With Alarm System
Old 06-06-2010, 05:20 PM
shadowjeep shadowjeep is offline
Re: Yes...Another Welding Bench...Oh My God!
that is just cool. very nice placement of tools. and i also like the alarm system.
Old 06-06-2010, 05:22 PM
Leveling feet in case you guys need an idea, these are 7/8 bolts with a washer welded on. The nuts fit nicely after knocking off a could of corners and press fitting inside 11 gauge 1 1/2" tubing. The bolts were turned on my lathe to both flatten the heads and true up once welded.
Old 06-06-2010, 06:32 PM
Mellotron Mellotron is offline
This thing is very nice; I like the adjustable feet. Is anything supporting the front of those lower shevles? (The corners closest to the rolling Miller)
Old 06-06-2010, 06:50 PM
dedmetal dedmetal is offline
What is the unit on the far left side plasma? what model?
250DX
MM251
MM175
225G plus
251D-1
Old 06-06-2010, 07:03 PM
Bob the Welder Bob the Welder is offline
Nice design, well thought out. But why all the nuts and bolts with those welders available?
“There’s class warfare, all right, but it’s my class, the rich class, that’s making war, and we’re winning.” Warren Buffett
American by birth, Union by choice! Boilermakers # 60
America is a Union.
Old 06-06-2010, 08:27 PM
duaneb55's Avatar
duaneb55 duaneb55 is offline
Nice job 200! Handsome dog.
Bob, I believe the bolts would be to allow breaking it down for transport when his TDY is up.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 06-06-2010, 08:35 PM
gordfraser gordfraser is offline
yea, what is that blue thing on the left end?
radio??
good compact design...tidy.
why all the bolts on the frame?
G
Old 06-06-2010, 09:02 PM
sn0border88 sn0border88 is offline
If you want it to stay flat you really should think about putting some supports across the middle, or else that table is going to look like a drain pan in short order.
Have we all gone mad?
Old 06-06-2010, 10:11 PM
Gents:
Yes the bolts are for disassembly it may need to go into a U-Haul Trailer, otherwise it would have been welded solid. Drilling all those holes without a drill press was a Cast Iron Bitch, never again.
sn0border88--you are right I was thinking of a couple of middle supports with flanges on each end to bolt up to the legs. I was thinking of using the 1 1/2" tubing. The 3/8 plate is close to 300 LBS.
gordfraser--that blue radio thing on the end is a Thermal Injection Rotary Left Handed High Speed Plasma Cutter. It was an early Miller Spectrum 300 good for 3/8 plate but I have pushed it to 5/8. I have had it since about 1998. Great little unit. Someday will be an upgrade to a unit that will cut 1". The Motorguard Filter is down below it.
Mellotron--no supports on the shelves, I know it looks odd but I didn't want anything obscuring a broom. I have another table like this that has gone for over twenty years that way and still dead square.
To all--thanks for the kind words.
Old 06-07-2010, 04:10 PM
Combat Jump's Avatar
Combat Jump Combat Jump is offline
Very nicely done! But shouldn't it be blue?
Miller 211 MIG
Miller 375 Extreme Plasma Cutter
Miller Maxstar 150 STL TIG
Oxy-Acetylene torch
Old 06-07-2010, 07:21 PM
Originally Posted by 200mphbusa View Post
Gents:
How small are the doors in the uhaul trailers there?
G
