HELP... miller 330 a/bp
Hi everyone just picked up a miller 330 a/bp machine.Never ran one before wonderd if anyone had any pros and cons on them and also any start up help .Have not fired it up yet was wondering what are the recomended settings for tig on this machine to start it up and see if it works properly . Have heard these machines are bullet proof minus the sore back from picking up this beast luckily came on a cart with casters.Came with 3 totes of acceseries tig torch, pedal ,3 stick leads,mig spool gun and millermatic box.Seems in good condition for its age I paid $500 for it any advice suggestions before I fire it up would be greatly appreciated.Plan on hooking it up to 100 amp service with a 60 amp breaker hard wired directly to a seperate breaker.The guy said the points needed to be adjusted.Plan on using it for strictly tig mainly mild steel.
Re: HELP... miller 330 a/bp
I have the same machine and I LOVE it!
All I do is tig with it.. Set it up and start small but the range of what you can do with it is unreal.. Member 7A749 can fill you in on anything to do with these machines... ...zap!
i have one too and love it. if you send me your email i can send you the technical repair manual for it.
Dynasty 200DX Passport plus w/ spoolmate 100 victor 315c oxy/(act and prop) Miller digital elite milwaukee power tools |
Thanks just got it home this morning.Was surprised how good of shape it seems to be in very little dirt dust on the inside wires cables contacts seem to be in very good shape thinking I did ok for $500.Not to sure what these models go for. Have not had it powered up yet (knocks on wood) the high freq and everything works.Does anyone have one of these or know how much power this machine will draw.Hoping my power bill wont go up to much plan on hooking it up to a 100 amp service and a 60 amp breaker.Probally running it between 50 to 75 amps mainly 12 to 16 guage mild steel.
At $500 for everything you got with it and the shape it's in you got a steal or a deal. A 60A breaker will likely get you in the 200A output range but much more than that and you be tripping it. Of course you'd have to be doing a whole bunch more than 12-16 gauge mild steel to get up to and above 200A.
If your load center has thru power terminals at the base of each breaker feeder leg just run your outlet from there (thru a disconnect box) and you'll have the full 100A required by the machine for 230v operation. Only problem is if you trip the breaker now you'll loose your lights too. Not sure if that set up is OK with NEC so maybe Sparky, MoonRise or someone else can clarify.For your set up to do 12 to 16 gauge mild steel you're definately looking at the LOW range setting and Fine Current control probably down around 20-30 is my guess. DCEN polarity switch setting, 1/16" tungsten, #4-6cup, 12-15CFH on the 100% argon. That's where I'd start and go from there. Oh, and congratulations on the 'new' machine.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
WOW! What a clean unit and with all the accessories you did good.
Manuals available through Miller site. 60 amp breaker with the correct wiring , it'll be fine for what you describe. You didn't mention it and I don't see a water cooler. Did you get one of those also? If it's an air cooled torch the duty cycle will be what the torch can handle. Either way, you have a machine that will serve you well. The biggest thing at this point is to pay attention to the bar on the left side under the HF panel. Connection for "Inert" and "Metallic". It DOES make a difference. Inert = TIG, metallic = Stick. Double check the gas hose to make sure it's on the gas valve and not the water valve. Tig on M/S. Set the HF to start not continous. That will give you nice arc initiation. In the off position it's a scratch start. millrat |
One has left hand threads..The other right hand threads.. ...zap!
Damn you Zap!!!! $500.00 is a STEAL. Wish I was where you were, woulda dropped the cash fast. Never used one, but I read the specs and they are pretty impressive. If it works properly and with the extras I think you did great on the $$$'s. Good luck with the new tool!!!!!
I'm spending my Kids inheritance, I dont like him that much anyway!!!!!! Enuff tools to do the job, enough sense to use em. Anybody got a spare set of kidneys? Trade? |
I paid 600 for mine...
Got it last October.. The Original Poster paid 500.. Either and or.....Good Deals!!! The machine in the pic looks just like the one member 7A749 had for sale.. And he is in Michigan also..... ...zap!
That one is sitting in my shop now!
#1. If you don't like what I wrote, or if it offends you, then don't read it! #2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**! |
I just decommissioned mine, placed it in the very back of the barn. I see them go as low as $200.00 sometimes. Couldn't part with it for that!
They are also a very fine SMAW machine, I'd say even better than my Dynasty 300. I had mine on a 95-amp breaker. When your capacitors for the high freq go out there is a guy on ebay who sells them really cheap. Miller wants over $100.00 each.
Dynasty 300. V350-Pro w/pulse LF-72 SG Spool gun LN-25. PowerArc 200. 5 SA-200s. 1800 Ellis saw Powermax 1250, CNC table. PROFAX Welding Positioner. JD2 model 3
Oh gezzs, it's been about five years now. I remember he was a Canadian. If you used the keyword “capacitor”, that would probably be about two weeks worth of reading.
Seems as I remember reading something about him selling capacitors here recently on Hobart, or was it Miller? Sorry for not being any more help! Oh I do remember reading on one of these sites where people said a good electronics supply house will have them also.
i got mine for 150 with spoolgun, and water cooled torch.
Thanks for the replies..........Picked it up from a guy who took it as payment on some money he was owed.He had it in his garage never used it was to big for what he wanted to do.Have the electrician coming over this evening to wire her up.Didnt come with a cooler just a torch 2 stick leads a 25 and a 50 footer quick disconectand a millermatic box with spoolgun.Just gonna run it aircooled picked up a new weldcraft wp-9 torch over the weekend and a new ground clamp.took of the panels and blew her out yesterday very little dust inside wires all look like new.The bar out of the conector will be in the inert posistion correct?if I have it pushed down into the conectors it will be in metallic correct?
Alas, as was mentioned, I was not the previous owner. I bet it has a selenium rectifier inside it. The Gold Star sticker was an indication of that. That's quite a clean machine. You got yourself a good deal. ![]() The spoolgun was gravy on top. ![]() Yeah, the throw switch stays in the out position to bring in the balance resistor for TIG. Metallic for stick. Have fun with it.
Specializing In The Sale & Restoration Of Miller 50 Series Wire Feeders Miller Maxtron 450 Inverters |
AHHHHHH..............SHE RUNS LIKE A CADILLAC!!!
![]() Finally got her hooked up today and fired on the power and layed a bead .Gonna take a little gettin used to till I fined her sweet spots.But breathes a sigh of relief everything works !!!!Best $500 I ever spent. ![]() ![]()
#19
Sweet!!!
What'd you wind up doing for your power hook-up?
#20
![]() Wait until you do Aluminum... ...zap!
#21
Hey bullgod,
As the others have commented, that is a really clean unit..... you did good. With all the accessories you got, a real bargain at the price. Denny
Complete Welding/Machine/Fab. Shop Mobile Unit Finally retired *Moderator* "A man's word is his honor...without honor there is nothing." "Words are like bullets.... Once they leave your muzzle, you cannot get them back." |
#22
Those are super machines. I had the exact same in an Airco, I gave a grand for it and sold it to one of my old bosses for $900....not bad after many years of service.
They weld aluminum very nice,esp. if you rig up a remote button to the contactor. Then you can bump weld like an old pro.
Miller Dynasty 700 ![]() Miller 350P ![]() Bobcat 225 NT Dynasty 200 DX ![]() 30-A spoolgun Spectrum 300 Enuff power and hand tools to fix or create one of anything but mass produce nothing!!! |
#23
Works fine .Still miss my Syncro 300 though!!!!!!Nothing against the 330 .
#24
Anyone of you guys with a 330 notice a big increase in youre electric bill
#25
electric is included in my rent, so no.
| Tags |
| haelp miller 330 a/bp |
