Old 06-30-2010, 07:53 PM
trook trook is offline
c-channel for table top?
I remember seeing a table a while back that used c-channel instead of plate for a top. It seemed that the OP stated that 6" wide channel with approximately 2-4 inch gaps between each piece made the table much easier to use clamps, etc. It seemed like the cost and weight were less too. Any thoughts?
Old 06-30-2010, 08:09 PM
forhire's Avatar
forhire forhire is offline
Re: c-channel for table top?
This one was on Practical Machinist:
http://www.practicalmachinist.com/vb...rt-2-a-194652/
Old 06-30-2010, 08:33 PM
ed mac ed mac is offline
thats a nice table but i still
would rather have a 3/4 or
1" solid top
Old 06-30-2010, 08:43 PM
Eric N Eric N is offline
1" solid top
I agree, I like a nice flat surface. Also, the back side of C Channel tends to be pretty concave, and the gaps inbetween I think would get in the way more often the they would help with clamping.
Old 07-01-2010, 03:00 AM
bassboy1 bassboy1 is offline
I like the idea of the gaps, but I'd rather it use 1 inch plate, 8 or so inches wide, as opposed to the channel. The channel is going to be near impossible to clamp to, without making a clamp that bridges two channels. The plate will allow clamps in the gaps, as well as being thick enough to drill and tap holes for various thread in accessories, or just drill holes for hammer in bench dogs.
Who is John Galt?
Old 07-01-2010, 10:26 AM
AndyA AndyA is offline
Having the table bolted together might be nice for moving. Unbolt it and break it down into parts that are more easily carried. On the downside a bolted table may not be as solid. Bolts with tapered alignment pins would be nice, but way more work.
A table with c-channel or plates might have another advantage. You can remove some of the pieces in the middle of the table. This might be nice if you have some odd shaped blob or stuff sticking out of the middle of your workpiece.
MM210, For sale $1k with cart,reg,gun,hose, and 250cf bottle
Dynasty200DX w/coolmate1
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Rage3
Jancy USA101
9" SB
9" Craftsman/Atlas lathe (worn out)
AEAD-200LE
