clear coat-seal for rusted metal???
I'm currently doing a ornamental cladding job for a client. The work is going into a turn of the century factory building converted into lofts/condos. I aged the steel being added to a nice surface rust. Know I need to seal the metal. The client does not want a gloss clear coat and wants the rough texture( feel) to remain. I have used clear enamels and lacquer on past projects, but both gloss over. Any one know of a sealer that works while having minimum distortion to finish? I will post pics tomorrow.
Miller TrailBlazer 251 Miller HF-250-1 Miller MaxStar 150 STL HyperTherm PowerMax 380 plasma Lincoln PowerMig 180 Millermatic 252 Last edited by wagin; 07-26-2010 at 03:14 AM. Reason: pics |
Re: clear coat-seal for rusted metal???
Hi Wagin, this is the toughest clear coat stufff I have used.
It's water based and dries clear. Larger hardware stores and Home Depot usually carry it. Whether it is available in a semi-gloss, I don't know.
Rick V
It's going to be a crap shoot either way. Two problems - 1) if the chemicals used to rust the material is not neutralized completely, it will out-gas and cause the clear to blister/fall off. 2) a clear still needs some sort of substrate to bond to, rust not being ideal. The way to cheat this would be to put a ton of something like a polyurethane clear to "bridge" over the rust, but you will start to lose your texture, and it will probably start to degrade the appearance. If you do try a clear, you may want to add a retarder to it to give it time to "saturate" the rust.
Unfortunately, this is a common problem in the sculpture world, and the reason why the people who are really concerned with keeping a long-lasting rusted finish without corroding too heavily are forced to go to something like an A588/Cor-Ten weathering steel. |
I do allot of custom rusting in my work. On lightly rusted stuff, I get it clear powder coated. Gloss, but I used to get a "satin" one too, but used up what they had. The company rep couldn't believe that we where coating rusty stuff. But it's not heavy rust and I do more then just let it rust away to get the finish. Your rust needs may be too heavy for PC.
200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack. |
Thanks for all the great info.
What I've done is scuff the mill scale, soak with water( a few rainy days works best), allow to rust a few days then clean the metal with mild soap and then windex. I tried acids, salt brine, etc...Old fashion rain seem to provide the best, most consistent rusty finish.
Miller TrailBlazer 251 Miller HF-250-1 Miller MaxStar 150 STL HyperTherm PowerMax 380 plasma Lincoln PowerMig 180 Millermatic 252 |
Distilled water works equally well.
I discovered some new chemistry, new to me any way. From my recent experimentations in aging-rusting metal, I had a container filled with lemon juice. I dropped a galvanized bolt into the lemon juice and the fun began. Bubbles, mild smoke and some noticeable heat in the bolt. A cool reaction. After a few minutes the once silver-gray finish on the bolt turned to a dark gray, almost flat black. The fumes/smoke concerned me a little. Does anyone know the specs. of this reaction? By-products, etc...
Wes
At a guess I'd say the lemon juice contained citric acid.
Galvanized means a zinc coating. Citric acid + zinc = zinc citrate + hydrogen gas
Rick V
So with a few hundred gallons of lemon juice and several tons of galvanized bolts I could generate enough hydrogen gas to run my car for a few days? Of course the required mods would have to be made to fuel system prior. Any way cool fact.
Not sure you could run your car, but you could sure blow up your garage trying!
From my own experiments with it, I am guessing that it takes more money in electricity to make a small amount of hydrogen. I don't think it is a viable method of creating cheap energy. Steve
DAY-JOB Web Designer/electronics tech http://steven-waller.com/ TOOLS Associate Degree Electronics Bachelors Degree Economics Over 40 years School of Hard Knocks Miller Thunderbolt LX ac-dc Politically RED Last edited by rookie_steve; 07-28-2010 at 07:23 AM. |
wagin,
As mentioned, acid + galv = hydrogen gas and no more galv. And as rookie_steve mentioned, you use more energy (electrical) to split the water into hydrogen and oxygen than you get by burning the hydrogen and oxygen and turning them back into water+heat(energy). You end up with a net energy loss. And that doesn't even take into account all the process inefficiencies involved! Even in a best-case no process inefficiencies scenario, it -still- takes more energy to electrolysize water into hydrogen and oxygen than you get from turning hydrogen and oxygen into water and heat/energy. But that doesn't seem to stop Democrats and other weak-minded folks from thinking that using electricity to split water into hydrogen is some sort of magic cure-all for energy woes. Back to the original question. Most of the time, coatings are made to film over and smooth out. In this case, you want something that does not smooth out. Tough call. Depending on how much protection you are needing for the pieces will determine how tough and durable a coating you need. Just remember, from back when you first asked your question on how to rust steel, I think I mentioned that given atmospheric moisture the rust would tend to continue. It is sort of a self-perpetuating reaction. That said, maybe a hot wax coating or a hot clear plastic (aka powder coat) could work for you if you first do a thin coat to seal and penetrate the surface rust and pits, and then 'glop' on another coat or more to put some roughness back onto the surface. Either that, or with a paint/varnish/lacquer coating, put on thin thinned coats either spray or brush or dip/dunk to get the sealing of the surface, and then do a 'poor' top coat with orange peel and 'dry spray' and overspray and pretty much all the stuff you never want to get in a sprayed on finish in order to get some roughness and glop.
The best laid schemes ... Gang oft agley ... |
At my previous employment, where i worked for 14 yrs until they down sized to mex....,a group of techs. researched and proto typed many hydrogen generator cells. A few were installed into the fuel system of various vehicles. The "lab work" was going fine until the day one tech decided to bubble off hydrogen, capture it in a windex bottle and guess what...fired it off to see if would blow. It did! he lost hearing for 3 days. That ended the R&D dpt.
I would say he was lucky!
Thanks Moonrise, for the excellent scientific explanation. ![]() Steve
DAY-JOB Web Designer/electronics tech http://steven-waller.com/ TOOLS Associate Degree Electronics Bachelors Degree Economics Over 40 years School of Hard Knocks Miller Thunderbolt LX ac-dc Politically RED |
The only way hydrogen fuel would even remotely make sense in the least, is if it was generated using nuclear power. PERIOD.
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon 300 inverters, XMT304's, 250 Ton pacific 12' press brake, 1/4" 10' Halco Atlantic shear,Koikie plasma table with esab plasmas. Lincoln idealarc tig 330A with bernard cooler. |
Negative... I own a large electroplating shop here in the west coast. We use both Nitric acid and hydrochloric acid to strip zinc (and other metals) off of parts. Using citric acid on nuts and bolts isn't going to blow up the garage.
Lincoln Power Mig 216 Lincoln Power Mig 140c Lincoln Precision TIG 225 Miller 211 Miller 375 Spectrum X-Treme Milwaukee band saw Milwaukee 4" & 9" grinders Milwaukee 14" chop saw Milwaukee Dry Cut saw Makita Drills |
But the same environmentalists wanting hydrogen power are likely to block such a possibility from ever happening. Steve
Steve
DAY-JOB Web Designer/electronics tech http://steven-waller.com/ TOOLS Associate Degree Electronics Bachelors Degree Economics Over 40 years School of Hard Knocks Miller Thunderbolt LX ac-dc Politically RED Last edited by rookie_steve; 08-01-2010 at 03:54 PM. |
