my weld beads
what do you think
a but weld weld in a push at 160amp with 7018 dc rods [IMG] [/IMG]this is abut weld in a pull direction at 160amp with 7018 dc rod [IMG] [/IMG]this is a T joint weld and it is on a push direction 160amp 7018 dc [IMG] [/IMG]
Lincoln Power Arc 4000 Thermal Arc Fabricator 252 i Thermal Arc 26 tig Tweeko 200 amp spool gun Hobart AirForce 400 Miller Suite Case Xtreme 12vs WP-17V-12R |
Re: my weld beads
Dont push, you pull 7018.
Other than the valley of slag that is probably hiding under the push beads, looks pretty good. At 160 amps you are a little on the hot side, so if you ever run out of position be prepared to drop down around 30-50 amps.
Have we all gone mad? |
