Old 09-24-2010, 11:05 PM
jakeru jakeru is offline
Repaired motorcycle crankcase cover
A customer had a broken honda motorcycle crankcase cover that was some kind of die-cast looking aluminum alloy. Not much ductility in this alloy, as it had fractured into many pieces.
I was concerned it was zinc-laden pot metal, but test weld showed no zinc burning, and file test showed it was soft like regular aluminum. I welded it up with 4043 filler rod. I advised the customer on an initial visit how to prep the piece for welding, and sent him off with a scrap of 3/16" thick 6061, which he trimmed and nicely formed into a patch piece to replace the many fractured pieces. I welded inside and out and got full penetration. Seemed to go smoothly.
Customer is an auto body / paint guy, and plans to smooth it out and match the paint to make it look as if it were never damaged in the first place.
Got a little stinky at the end there (oils were off-gassing from the heat...)
Old 09-25-2010, 12:21 AM
norite norite is offline
Re: Repaired motorcycle crankcase cover
Great looking repair, I'm sure your customer can sand/buff the outside of that cover so it looks like new.
SA 200
Idealarc 250 AC DC
MM200
MM251
30a Spoolgun & WC24 Control
Square Wave Tig 175
Invertec V350 Pro
SC-32 CS 12 Wire Feeder
Oxweld/Purox O/A
ArcAir gouging torch
Need Plasma
Old 09-25-2010, 03:18 AM
Shox Dr Shox Dr is offline
Nice, I've repaired quite a lot of motorcycle casings and Mr Honda's are real nice to weld
Old 09-25-2010, 12:16 PM
Rojodiablo's Avatar
Rojodiablo Rojodiablo is offline
Great job!!
Old 09-25-2010, 01:00 PM
Thanks, I was really concerned it was pot metal and going to melt into a big blob right on the table, but actually welded up really nice. The oil offgassing fumes were getting pretty bad at the end there, I remember it was just "steaming on the table" at the end there and stunk really bad. But, the oils did seem adequately removed/prepped clean in the areas I needed to fuse the metals together, and veeing the weld joints helped a great deal. (There was just one small "oiled crack" crack that was not vee'ed out... I had to take a second pass over that one to melt out the oil and metal all the way down to the bottom.)
Old 09-27-2010, 09:16 AM
Fegenbush Fegenbush is offline
You may want to consider having the gasket surface scraped by a machine shop. It would definitely make it easier on you during reassembly. I'd do it for next to nothing if you were local.
Old 09-27-2010, 04:09 PM
DieselWarrior's Avatar
DieselWarrior DieselWarrior is offline
Nice, I like how you jigged it up prior to welding. Helps keep it in alignment while you weld. MIG or TIG??
Old 09-27-2010, 04:59 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
GTAW for sure
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Old 09-29-2010, 04:44 PM
Fegenbush - thanks! I wish I knew a local machinist who could do small jobs like you offered without a lot of hassle. At times there are small things I would like faced or turned on a lathe, or parts like manifolds, etc surfaced flat after I weld them. You not in the greater seattle area, by chance?
Diesel - It was indeed TIG welded; using an Everlast Super200P. And yeah the customer did a good job of jigging it up, with the wood brace pretty much holding the perfect position for the first couple tack welds. (Not much good leaving it attached after that though, heat of nearby fusion welding would have converted it into charcoal.)
