Old 10-13-2010, 04:51 PM
jimrockireland jimrockireland is offline
Welding technique
I am stick welding with a Lincoln 225 AC stick welder. When doing a standard flat weld is it OK to re-weld (re-liquify; back track) a section of the weld in the same pass for the purpose of building up the weld a little more? When welding over a previous weld is it OK to just remove the slag with the hammer or should you grind the previous weld first.?
Old 10-13-2010, 07:13 PM
DesertRider33's Avatar
Re: Welding technique
You should stop and chip off the slag before welding back over where you've been, since the slag has likely already solidified, if I'm understanding your question correctly.
Unless there's porosity, slag inclusion, non fusion, etc defect that needs to be ground out, you can put in subsequent passes without grinding. Scratch/chip/brush off the slag and weld.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 10-13-2010, 07:30 PM
i4sillypwr i4sillypwr is offline
I think he's talking about whipping back into the already solidified puddle during the weld. I think....if so that depends on the rod and who you talk to.
Old 10-13-2010, 10:45 PM
tanglediver's Avatar
tanglediver tanglediver is offline
The time it takes for weld metal to freeze is very short. Not much after that, the slag hardens up. That slag needs to come off before you add another bead.
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 10-13-2010, 10:50 PM
Taiden's Avatar
Taiden Taiden is offline
if you're talkn gabout whipping (ie, while you're laying an arc, go forward, then step back *slightly*, then go forward, and repeat)
that depends on the rod and what you're doing. For example, 6011 we are told to whip in class, but 7018 we are told not to (can't remember polarity)
Old 10-14-2010, 01:34 PM
I was referring to what i4sillypwr describes: whipping back into the already solidified puddle during the weld. I have noticed my welds seem to be pitted. I am welding 1/8 inch mild steel using 6011 3/32" rod at 60 amps.
Old 10-14-2010, 06:43 PM
You shouldnt have a problem whipping 6011. Amps seem a little light which could cause your problem but not all machines are the same so i dunno. I'm not the most experiance stick weldor so hopefully someone else will chime in.
