Old 11-23-2010, 10:05 PM
trouble007 trouble007 is offline
shopmaster 300 ground clamp
So as the title states i have a shopmaster 300. I'm looking to set it up for stick welding, on the front theirs two sets of output lugs one set for the mig and one set for the stick/tig. my question is can i just leave the work lead connected to the mig output stud and run a jumper over to the stick/tig output stud to use as a ground for stick or do i have to disconnect the work lead from the mig stud and put it on the stick stud?
Any help is appreciated
Thanks
Ryan
_______________________
OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Old 11-24-2010, 12:33 AM
Stick-man Stick-man is offline
Re: shopmaster 300 ground clamp
That you will probably have to ask Miller. I have a late model Shopmaster 300 and I have four of the Tweco #2 quick disconnect lugs on it. Name:  000terminal.jpg
You might run into a problem if you ever have to run straight polarity like on flux core.
"Stick-man is wise" - Farmall
"Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550
"StickyFingers-man"
Commander 500D, LN25
Shopmaster 300, Super S-32P
Hypertherm Pmax 600
Smith & Oxweld O/P
Old 11-24-2010, 03:49 PM
DesertRider33's Avatar
Originally Posted by Stick-man View Post
That you will probably have to ask Miller. I have a late model Shopmaster 300 and I have four of the Tweco #2 quick disconnect lugs on it. Attachment 58568
I was just going to suggest doing that. I have those on my Bobcat too.
MM350P/Python/Q300
MM175/Q300
DialarcHF
HTP MIG200
PowCon300SM
Hypertherm380
ThermalArc185
Purox oa
F350CrewCab4x4
LoadNGo utilitybed
Bobcat250
XMT304/Optima/Spoolmatic
Suitcase12RC/Q300
Suitcase8RC/Q400
Passport/Q300
Smith op
Old 11-24-2010, 04:03 PM
thanks for the advice. i was originally just planning on putting the QCs on but thought i would ask if this was possible.
Thanks
Ryan
Old 11-29-2010, 01:20 AM
ccawgc ccawgc is offline
stay with the QC and move your work lead. That way you won't cause a problem.
Old 11-29-2010, 01:35 AM
The reason for the 4 terminals is, they are your polarity switch.
If you tied both work terminals together You could not weld flux core wire and do positive stick with out moving your work lead any way. With a HF box, this welder can do TIG, MIG and stick. This eliminates a expensive polarity and process switch for this welder.
Most unit I have worked on use the QC terminal adapters.
