Old 11-24-2010, 09:44 PM
Ram48 Ram48 is offline
Help.
I am a hobbyist welder and am looking for a Tig. I want to learn the skill and will do mostly motor-sports type welding (when I get good enough) usually no more then 1/4 to 3/8 thickness both steel and aluminum. My question is what size machine will fit my needs and if I had to do 1/2 inch what size would handle that in multiple passes? I am looking at 200, 225 and 250 Amp inverter type single phase 220 welders.
Thanks
Ray Mc
Old 11-24-2010, 10:20 PM
DSW DSW is offline
Moderator
Re: Help.
If you want to do 3/8" alum you'll need at least a 250amp class AC/DC tig. If you want a decent inverter in this range get your wallet out. A Dynasty 350 new will set you back at least $9K and a Syncrowave 250 new will set you back almost $6K when you add in torch, cooler, cyl etc.. Even used expect to spend between $3K-6K. These are NOT "hobby class" machines. They are serious industrial machines.
If you back it down to say 3/16"-1/4" alum you can do it with a 200 amp class AC/DC tig instead. A Sync 200 or TA 185 with the air cooled torch will set you back about a bit over $2K new, and the Dynasty 200 will set you back about $4K. If you do much heavy alum you'll want to spend the extra bucks for the water cooled torch and cooler so add in maybe another $700-1000 or so. These are more on line with what the serious hobbyist would usually need.
Ronald Reagan
Old 11-24-2010, 10:52 PM
trouble007 trouble007 is offline
Re: Help.
I don't know what area you are in. In my area there are allot of slightly older machines such as the dialarc HF and 330 a/bp that are going cheap just keep an eye on Craiglist and you might just get lucky
Hope this helps
Ryan
_______________________
OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
