MM35 with poor strike arc
I have an old white face MM 35 that I have finally finished upgrading with a new gun, replaced all the rotted insalated cable. It seems as though It has a tough time starting an arc. Is it just the way it was back then or could there be a weak or bad component inside? Thanks and Merry Christmas
Re: MM35 with poor strike arc
I assume your referring to the millermatic 35?
Have you checked to see if the ground is connected in the machine correctly? Ive had one pull off the connection post before
Nothing like a good cup of coffee and the smell of 11018 burning in the morning. Navy Certified Welder |
Yes the MillerMatic 35. The outside connections are tight, And I replaced the cable leads back into the machine. I wiil recheck that, Thanks
jimco,
You could be looking at tired, old output capacitors. A long shot but maybe dirty weld contactor contacts??
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Is it possible to check caps? I will also check the connections. Thanks for the ideas.
Unfortunately, the typical quick charge/discharge test with a VOM doesn't tell you anything definate regarding capacitance, leakage, etc. For that a quality capacitor tester is required.
Just the same, the charge/discharge test can identify shorted/open caps and any that don't charge/discharge at the same rate as the others which can be used as an indicator.
Thanks for the info.......
