Time for a cold cut saw
Not the deli kind...
Looking at a Makita 12" Dry Cut Saw. 15 amp motor 60 tooth carbide tip blade On for $529CAD. What do you guys think? I'll have to run a dedicated circut to it, but there are only about 3 feet between the panel and the shop, so that isn't a problem. Anyone else have one? Likes? Dislikes?
Owner of Welding Wiki, The free wiki based resource for weldor's around the world. http://www.weldingwiki.com We have cookies!
i think dda has one
HUB IF it Catches...Let it Burn
I got it today. I'm in love.
Just curious how well do you think the blade will last? I was reading a review on another site, Dewalt was claiming up to 1200 cuts before their blade needs sharpening. Everyone that used it said 300-400 cuts was closer, some being much lower, but admitted that they pushed too hard and may have damaged the blade.
I got the exact you've got and I'm happy. Had a slight problem with a little bit of oil leaking from the casing.
Apparently the grease packed in the gearbox caused the seepage when it got hot. They repacked it with better grease and put in new oil at no charge. Enjoy. |
SteelMax has a good line of metal working tools.
I have had no complaints! |
Milwaukee 14" for me.
Don (dda) and I have the DeWalt DW872. I have cut some large stuff where the 14" blade was an advantage, but it's rare. I've heard the Makita's 12" blade is a little more forgiving when it comes to flexing, but I've not noticed a big flexing problem with the stuff I do.
I've dulled mine by cutting steel of unknown origin. Turned out to be hard stuff... Bedframe is a no-no also. Keep an abrasive around! |
Nice avatar Mac
Hey, the Mac is back!!
Yup, mine is great and still yellow. Keeping it clean for the moment. I am having oil leaking as well. My warranty is almost up, too. Better haul it in..like I have time for that. FWIW, I estimate I have about 900+ cuts on the original blade. It is definitely getting too dull. May need to swap soon. I cut some cold rolled 1 1/2 solid....dat did it in!
They begged me to return...
Told ya it had changed here.
It really has changed. Shoot...they made Chris a mod!
It was an honor to beg
![]() Welcome Mac
So besides you and I, Don, how many "Oldtimers" do we have?
Diver bill is here...hmm, thats I think about the last of the group. There are some good guys in here. Smithboy and sandy been around a while. I cant reemember them all now lol...but yeah were about last of the bunch I do believe....
OMFG I love your sig line mac
lol thats too funny
#19
Chris, I believe Mac meant from the original group way back at the beginning. There are a few, but not too many. The original fracas cleaned out most. A few stayed, and a couple have come back...but that is it.
#20
NnF |
#21
Yup, DeWalt DW872. I really like it. I am starting over with the blade, though. Had a slight accident a few nights ago while cutting a weld plate in two. Should have ground the bead down instead of shimming it. I still have not found the shim. The plate jambed up the blade and bent it pretty good. It only lost parts of five teeth, bent the blade and also bent a 1/4 welded coupon almost in half. Learned my lesson. New blade has 12 cuts on it and counting.
#22
I learned the hard way, too. Almost cut a chain...
#23
Well, it was nothing I hadn't done several dozen times before. I guess I was on borrowed time.
My thinking is that it was the dull blade that helped it along. It was acting "grabby" just a little before it happened......... I have to do the same cuts tomorrow. I will be grinding the welds down first...I only have one more blade left.
#24
Where are you buying your blades, Don? I need a new one soon and it's time to start looking around.
#25
I got all of mine from eWarehouseDirect's Epay store. They were the ones that sold me the saw in the first place. They had a run of the blades at 72 bucks.....I got two. Haven't looked for any in a while...might outta since I am down one now.
