which wire to use for aluminum?
Hi all, I have a Lincoln 3200HD which is MIG/flux-cored and have a quick q. I want to patch/fix a leaking car A/C which is made from aluminum. Which wire can I use for this job if I will not be using it in MIG mode (don't have gas).
thanks! |
I don't believe there is such a thing as a flux cored aluminum wire. Maybe, you should braze it using an aluminum brazing alloy and propane torch.
You will have trouble with any alu under 1/8 with MIG. Under 1/8 is TIG territory usually. Alu for MIG is solid wire requiring straight Argon.
I can't think of a single part on an car ac system that I would want to touch with a wire feeder of any type to repair a leak.
Smithboy... if it ain't broke, you ain't tryin'. |
Epoxy on a properly prepaired surface would certainly do the trick.
thanks for the replies guys
.. I'll probably try some sort of epoxy/sealant.
Aluminum solder works great!
Messer MG Eutectic makes a good solder! |
