Old 01-10-2011, 06:42 PM
dugndeep's Avatar
dugndeep dugndeep is offline
95578 4 1/2" grinder
I had a Harbor freight coupon for the 95578 grinder for $9.99 a burning a hole in my pocket and about to expire on 1-30-11 so I figured I had better get there and pick one up.I got a 4 1/2" grinder that I bought at harbor freight about 7 years ago that still works just as good as the day I bought it,I hope this one does the same.I'm going to put a cup brush on this one and leave it so I can clean metal and welds with it instead of having to use bench grinder with a wire wheel on it.It's a little smaller sized than my other one,maybe it will be a little easier on the hands to use.I put a little thin cut-off wheel on it just to see how it works.As for quality,time will tell.
Maxus Pro-125 Mig
Chicago Electric 90 amp DC flux-core
Lincoln Electric AC 225 tombstone
O/A torch
M/O mini-torch
10 acres of flatland
15 acres of holler
Old 01-10-2011, 07:16 PM
tackit's Avatar
tackit tackit is offline
Re: 95578 4 1/2" grinder
I have doubts the grinders electricals can survive a cup brush unless it's only going to be used occasionally, 4.3 amp motor is not big.
I got rid of a 5 amp metabo because a 4 1/2" grinding wheel would bog it down when I asked it to dig.
Old 01-10-2011, 09:52 PM
Jack Olsen's Avatar
Jack Olsen Jack Olsen is offline
Didn't someone recently do a tear down on one of these? If I'm remembering right, they'd made some improvements. I have 5 of the older heavy duty HF ones, and have never had a problem.
Old 01-10-2011, 09:56 PM
Bob the Welder Bob the Welder is offline
With a 4.3 amp motor and being sold at Harbor Freight, it probably has a Walt Disney cartoon character as a trade mark.
“There’s class warfare, all right, but it’s my class, the rich class, that’s making war, and we’re winning.” Warren Buffett
American by birth, Union by choice! Boilermakers # 60
America is a Union.
Old 01-10-2011, 11:53 PM
dugndeep's Avatar
I took it apart to make sure it had enough grease,I added a little more to make sure.I added some loctite to the screw threads so they don't back out.
It's not made to ride on,these thing's will last forever if you don't abuse them but so what if it dies,i'm out 10 bucks.Try the flap disc first.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-11-2011, 12:09 AM
dugndeep's Avatar
I got a 15 amp 9" grinder for diggin
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-11-2011, 12:25 AM
dugndeep's Avatar
It will handle this 3" twisted cup brush with ease.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-11-2011, 01:16 AM
LawsonWeldingLLC LawsonWeldingLLC is offline
I know someone who has a box about 24 x 24 by 10 inches deep full of the orange ones if u need parts , my makita's are still running strong lol if u get a chance goto fastenal and price there blackstone flap discs , they are 4.30 here at my local fastenal , and there a hell of alot better then those black n deckers just a thought
I forgot how to change this.
Old 01-11-2011, 02:36 AM
tackit's Avatar
For $10 it's not a big deal... good luck with it.
My favorite grinder is my 11 amp 5" Hitachi with a rat tail handle. I run 6" metabo? flap wheels and a 6" power brush on it. It's smaller over all size and lighter weight keeps the heavier 3 HP 7" Hitachi on the shelf.
Old 01-11-2011, 09:07 AM
jsm11's Avatar
jsm11 jsm11 is offline
Nice score....
With that said, when I'm leaning on metal it better disappear fast.
I'm using Dewalt's I believe 14 amp with the pistol grip.
Was like $130 and 4.5 inch.
The difference is night and day.
1981 Lincoln SA 200
Miller Trailblazer 302g
Miller 211 Mig Welder w/ Autoset
I'm learning to stick metal together
Old 01-11-2011, 10:29 AM
dugndeep's Avatar
How do you report a spammer on here?
shatacizsaicy might be a spammer.
Don't need no stinkin watch
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-11-2011, 11:05 AM
prop-doctor's Avatar
prop-doctor prop-doctor is offline
click on the little triangle to the right next to post number
to report spammmmmmmR
idealarc 250/250 ac-dc tig
idealarc 250/250 ac-dc tig #2 used for stick
lincoln sp100
hh125
dual arbor grinder polisher
30 yrs of hand tools
52 pitch blocks 6p-26p
rake gauge -pitch gauge
G&D prop repair
918-207-6938
Hulbert,okla 74441
Old 01-11-2011, 11:17 AM
Frank Chloupek Frank Chloupek is offline
Administrator
Spammer gone bye-bye.
Old 01-11-2011, 10:14 PM
Billdacat's Avatar
Billdacat Billdacat is offline
If that is an HF wire cup...you better watch out; you will poke your eye out.
HF wheels and cups are freaking dangerous.
I bought an HF 4.5 in pneumatic grinder for working on wet ground; not a lot of balls but it's not bad considering the price. ~$25
BTW: Are the internal gears made of metal?
Old 01-12-2011, 09:02 AM
dugndeep's Avatar
Harbor freight is having a blowout sale the 14th thru the 17th,they have this very same grinder for $9.99,might go buy two more so I can put different wheels on them.
They have metal gears and that cup brush is at tractor supply
I just don't see paying over $100 for a 4 1/2" grinder like a metabo.They almost look identical.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-12-2011, 11:21 AM
By dugndeep;
Until you use them, then the difference will become readily apparent!
America is a Union.
Old 01-12-2011, 11:42 AM
PapaLion's Avatar
PapaLion PapaLion is offline
Makita makes 4 1/2" AC and DC for use by the SA200 folks... IMHO Bulletproof and available at HD.
Lincoln Power MIG 215
Lincoln WeldPak 3200HD
Lincon ProCut 25
Lincoln WeldanPower 225 AC/DC
If all else fails... buy more tools
Old 01-12-2011, 02:51 PM
dugndeep's Avatar
Check out this wood carver blade for a 4 1/2" angle grinder.Says it's good for cutting holes in wood flooring & walls and just general wood carving or sculpting.Never seen one like this before.Just like a chain saw blade for an angle grinder.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-12-2011, 08:24 PM
moeh1 moeh1 is offline
I have one of these, it is actually a chainsaw chain sandwiched between two presssed washers. Awesome tool for shaping wood, logs, etc.
Old 01-13-2011, 12:28 AM
dugndeep's Avatar
I put a thin cut-off wheel on my new grinder to try it out and I really like it.It has a rubber like feel and is easy to grip.Just the right size to hold in your hand plus the rubber coating makes it easy to grip.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-13-2011, 10:41 AM
dugndeep's Avatar
I would like to get this guide and try out on cutting sheet materials.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-13-2011, 11:29 AM
dugndeep's Avatar
I got some really good bearings that will fit this grinder,debating whether to replace them or not.I know these bearings are alot better than the one's that come in the grinder,looks like another kitchen table project. I love to tinker
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-14-2011, 12:19 AM
gsport gsport is offline
how can you go wrong for $10.00... i think i have 4 or 5 of them, all with different wheels.... figure if one fails, i'll cut off the cord and make an extension cord out of it.. lol
Old 01-14-2011, 12:36 AM
dugndeep's Avatar
I put a few knurling's in the outer wheel flange with a dremel and a thin cut-off wheel.It makes wheel changes so much faster.
Maxus Pro-125 Mig
O/A torch
M/O mini-torch
15 acres of holler
Old 01-19-2011, 01:06 PM
rundogs rundogs is offline
I have that guide Dug,its well worth it.I cut the ends off of a reciever hitch and made a three point hitch for my tractor.Like cutting plywood!
[IMG] code is Off
HTML code is On
