Lincoln SA200 w/ Wisconsin VF4, Remarkable Condition
This Lincoln SA200 with a Wisconsin VF4 is in remarkable original condition, as close to mint as one of these could possibly be. It's always been garage stored and has seen little use. Has a new stinger and ground clamp, along with about 85ft. of additional leads. Also comes with the original Wisconsin instruction book with the parts listing. It hasn't been used in over 5 yrs. but ran perfectly when it was last shut off and put away. I'm sure the tank, filter and carb jets probably need cleaning and de-gumming, other than that she should fire right up. Asking $850.
Re: Lincoln SA200 w/ Wisconsin VF4, Remarkable Condition
where you located?
Got something to load it with?
1981 Lincoln SA 200 Miller Trailblazer 302g Miller 211 Mig Welder w/ Autoset I'm learning to stick metal together
Toledo OH...yes, I've used an engine hoist
you still have it ????
Howdy steeled4life - Your machine sure looks to be in nice condition.
If it helps anyone who may be thinking about a long-distance sight unseen purchase I'll mention that although this is an SA-200 in name, it's a completely different SA-200 than the typical Pipeliner. The "Junior" has a smaller generator, no auxiliary power, is air cooled, and has no automatic idler. Certainly still a very nice "pure" DC generator. Good Luck |
Yep...It's still available
This SA 200 is definitely not a "Pipeliner" The SA 200 here is a 1952 model. This machine is also not to be confused with a "Junior". The "Shield-Arc SA 200"Junior" is more thoroughly presented in Lincoln Electric Manual IM-107 available on the Lincoln website.
Sent you a pm
SA 200 square wave 175 pro airco 250 airco dip pac south bend lathe milling machine |
No big deal, but I'm certain that machines like this one were also labeled as "Junior."
http://www.lincolnelectric.com/asset...OLN3/IM107.pdf |
Denrep, Thanx for squaring me away on the my SA200. Absolutely it's a "Junior"!
