Old 01-28-2011, 09:00 PM
lawrence0485 lawrence0485 is offline
Harbor freight 110A mig help
Hey guys last night i was welding and all the sudden it just quit. All it will do when the trigger is pulled is click the contactor. At first id did this on the min/max 1 setting and now it does it on all settings. No wire feed, stinger isn't "hot". I did a resitance check between the electrode and ground and i can confirm that the contactor is closing when the trigger is pulled. Oh and the fuse on the pc board is fine.
i'm kinda thinking that the 1/2 switch is bad, because at first it did it on min/max 1 setting and worked fine if the 1/2 switch was on 2....
Anyone else had this issue?
Old 01-28-2011, 09:49 PM
Im no welder Im no welder is offline
Re: Harbor freight 110A mig help
Hope you paid the extra 30$ for the free replacement!
Thats all I know, Good luck either way tho!
Old 01-28-2011, 10:23 PM
No replacement, i got it off ebay for like 60 bucks. It was a harbor frieght return. The PO apparently didn't know how to weld and blamed it on the welder...
Old 01-28-2011, 10:38 PM
Ahh damn. Well I hope its something simple and cheap. But atleast you aint out to much money if not.
Old 01-29-2011, 12:01 AM
Bluewelders Bluewelders is online now
Either switch failing "1-2 or min-max" will give the symptoms you describe.
Just get one or both from Harbor Freight,probably will cost almost nothing.
Old 01-29-2011, 12:44 AM
California California is offline
I wonder if you could clip a jumper across each switch to test if that restores it.
Or use a meter and verify that the switches are intact.
Old 01-29-2011, 09:21 AM
Ya maybe later today i can get out there an play with it. I have a pretty strong feeling that it's the 1/2 switch since thats were the problem started.
Were are you guys getting parts for these welders?
Old 01-29-2011, 03:35 PM
Just call Harbor Freight 1-800-444-3353, Monday thru Friday,
6:00 am to 4:30 pm PST time.
Give them the Item number.
Parts are cheap, but sometimes they are on back order.
The switch may have had a fault, or some near genius may have been switching it while welding.
It should be easy to check with an ohm meter , if you take it out.
Just write which wire goes where.
Old 01-29-2011, 07:49 PM
ok guys it definetly was the switch. Luckilly both the min/max switch and the 1/2 switch are double pole/double throw so you have a spare switch built in. All i had to do was to m ove the 3 wires to the other side of the switch. Works good as new.
Can we get liners for these cheap whips from harbor freight?
Old 01-29-2011, 10:51 PM
The last person that I know of, changing the liner out was this post.:http://weldingweb.com/showpost.php?p=463472&postcount=5
[IMG] code is Off
HTML code is On
