How much do you think this ring gear weighs?
I was asked about removing this ring gear from the building it is in, just trying to make a guesstimate on how much it weighs.
The picture is not the best because it is a picture of a picture but you can get the idea from it. I haven't seen it yet but the info given to me was as follows. The gear stands 101 1/2" tall, 5 3/4" wide and from the edge of the teeth to the inside edge is 3 3/4 thick". Any guesses?
I am what I am, Deal with it! If necessity is the Mother of Invention, I must be the Father of Desperation! |
Re: How much do you think this ring gear weighs?
I'm guessing it weighs approximately alot...
(Retired) Professional firefighter, amateur everything else I try to do... Oh yeah: Go Big Red! (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
212 pounds.
Let's start a pool!
Buy American, or don't whine when you end up on the bread line. |
950 lbs give or take.
I'm going to say 1150 lbs.
You get what you put in and people get what they deserve... |
2000 # + or - 5%
1 dollar bob lol...... 1800
My guess is the same as yours...2000 + or - a few lbs.
2336lbs
What is the composition of the ring?
Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma Cutter Sorry I had a bad stroke but now I am back. |
Assuming that the cut gears have a 'real' thickness of 3.25" vs the measured 3.75", Use a diameter of 101" (x 3.14) to get a length (circumference) of ~317", then 317 x 5.75" x 3.25 = 5924 cu. in. and 5924 cu. in. x 0.28 lb/ cu. in. = 1659 pounds, this assuming further that it's steel as it appears to be. . Last edited by Oldiron2; 01-28-2011 at 11:03 PM. Reason: added comma...... |
20oz per lb.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
I had assumed "edge of the teeth" to mean the tooth's root.
That is why I often tell posters that using good, clear, concise English is important. When details are not carefully given, often a number of interpretations are reasonable. Since we didn't base any bid on this one (and no prize was offered), I guess it doesn't matter too much here.
![]() FWIW, if you were/are correct and we assumed the "effective" depth is 4.0 inches, that would give a value of about 2042 pounds using my other figures. Within 2% of your guess. |
1940 lbs. minu the cutouts for teeth.
"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt |
1876 lbs minus the cutouts for the teeth.
I calculated the area of the entire circle (3.1415 X 50.75 X 50.75 = 8091.4)
I then calculated the area of the center of the ring (3.1415 X 47 x 47 = 6939.8) I then subtracted the center of the ring from the entire circle from (8091.4 – 6939.8 = 1151.6) I then multiplied the area of the ring by the thickness (1151.6 X 5.75 = 6621.7 cu in) I then multiplied cu in of the ring (6621.7 X .29 = 1920.3 lbs) I was not able to calculate the weight of the voids between the teeth because you did not supply tooth geometry this needs to be subtracted from the above weight to get the correct weight |
#19
The question is...can you cut it?
#20
d=101" so c= 26.44'
5.75" x 3.75"= .479' x.3125'=.148sf ignoring tooth profile x26.4lf=3.95cf assuming steel @ 490#/cf=1936 pounds. |
#21
Just a thought for you fellows who need to figure the tooth cutouts, try figuring a ring with a ID from the root of the teeth and the current OD and half that amount which would account for the cutouts and add that to the remainer of the ring. You would need to know the depth of the teeth to do this. Have fun.
#22
1630 lbs
#24
Wife sez: " One thousand, two hundred and ten pounds. I can tell just by looking at it."
I say: Does not matter how much it weighs. Four strong guys. Set it on the floor. Roll out without tipping or going too fast. Flop onto trailer deck, and move around with bars till happy. Carry on.
#25
1,120Lbs
~ Journeyman Steel Fabricator ~ |
