Old 01-30-2011, 09:34 PM
jw3's Avatar
jw3 jw3 is offline
Manual layout for coping pipe
Does anyone know how or where to find theformula to layout coping cut lines on pipe. I might be saying it wrong so please don't poke too much fun at me. I know about the mitre programs on the Internet,but I don't have a computer or printer in the shop. Thanks again
Miller Bobcat
Harris cutting outfit
Miller spectrum 625 plasma
Variety of shopmade tools
Old 01-30-2011, 09:43 PM
SRO1911's Avatar
SRO1911 SRO1911 is offline
Re: Manual layout for coping pipe
The search at the top of the page will give you a ton of info. Here are a couple of threads that go into a great deal of detail on it.
http://weldingweb.com/showthread.php...ghlight=Coping
Old 02-25-2011, 09:12 AM
neckless neckless is offline
Location: dryden ontario canada in the middle of no where
the pipe fitters hand book every welder should have one ,the is everything you need to know about math and formulas and then some
Old 02-26-2011, 10:26 PM
oxygen454's Avatar
oxygen454 oxygen454 is offline
How big is your pipe? If the pipe is small for handrail, there is tricks to use with out calculations. Im guessing the pipe is larger? Layout will be needed in that case.
The second post in the first link supplied above is an excellent way of finding your copes for both pipes. That is what they teach in fab school.
What sizes of pipe are you looking to cope? Also what angles will the pipes intersect each other?
~ Journeyman Steel Fabricator ~
Old 04-04-2011, 10:50 PM
jw3's Avatar
jw3 jw3 is offline
It is for 1 1/2" and 2" pipe. Any short cuts or formulas would help
Miller Bobcat
Old 04-04-2011, 11:08 PM
Pro-Fab Pro-Fab is offline
If you are going to be in the trade, pick up the pipe fitters handbook as has been suggested already. No formula is required, but you have to have an understansing of pattern developement before you could possibly understand a written explanation without first looking at a sample layout. Until you pick up a copy of the handbook, you could google 'pipe layout' or pattern development'. The pattern will change with each pipe size and different intersecting angle, so it is a good practice to transfer your pattern onto light gauge sheet metal, or other durable stock for future use.
Old 04-16-2011, 03:01 AM
weldbead weldbead is offline
try this.....snip.awardspace.com.............
Old 04-27-2012, 06:21 PM
MainePiper MainePiper is offline
Lateral app for android from LMF.Services very slick and easy to use
Pipe Fitter Calculator
https://play.google.com/store/apps/d...fittings.kevin
Lateral Pipe Calculator
https://play.google.com/store/apps/d...y.trigonomitry
Mitered Pipe Calculator
https://play.google.com/store/apps/d...lculator.miter
Old 07-03-2012, 07:34 PM
jw3's Avatar
jw3 jw3 is offline
I found something I thought I would share. I found a book called Pipe Template Layout by Thomas W. Frankland. More info in this book than I will probaly ever use.
Miller Bobcat
Old 07-06-2012, 11:17 PM
sjmj1966 sjmj1966 is offline
templates are great, but you still need to have an understanding of how those templates were made. get the pipefitters handbook, learn and reference it when needed, then make your own templates. you cant always rely on a computer to be on the jobsite.
Old 07-06-2012, 11:44 PM
walker walker is offline
Are you trying to make a 12" branch tee, or pipe fence?
Old 12-05-2012, 11:21 PM
Ultralow787 Ultralow787 is offline
jw3,
Is this what you were looking for?
http://www.trick-tools.com/Individua...l_Pipe_NPS_735
These are contour gauges for pipe or tubing and come in sizes up to 6"
[IMG] code is Off
