Plasma Help
First off let me say hello to everyone as I am new to the site and this is my first post. Now then, I picked up a Miller Spectrum 500 last Friday for $400 including a small box of consumables. It worked fine when I tried it at the previous owners shop when I tried it on some 1/8" plate. I am totally new to plasma and have no experience with it. I went to use it to slice a new piece of exhaust tube the other day. It started fine and ran fine until the main arc kept going out leaving just the pilot arc. I tried adjusting the air pressure and distance and it didn't seem to help.
Sorry for the long first post, but any help anyone can give is hugely appreciated. |
Re: Plasma Help
Sounds like a bad ground to the work.
Re: Plasma Help
Is there a minimum thickness a machine like this can not go below?
Re: Plasma Help
Leo |
Re: Plasma Help
Ok, I was on the low setting and it would cut fine for 1/2 inch then loose arc. I was using the standoff for the high range can the tip touch on the low range? It was like it would go out after i couldn't move fast enough to keep up with it.Sorry for the questions, I am completely new to plasma)
Re: Plasma Help
Sorry, I'm not familiar with your machine.
With my Hypertherm if I go too slow I will lose the entire arc. The way you first described it, it still sounds like the ground is losing contact. I have started to make a cut only to realize the ground clamp isn't on, I will have my pilot arc but all that happens is the work is etched for lack of a better description. Try it on a higher setting and increase travel speed. |
Re: Plasma Help
Ok I got to play with it some today for about 45 minutes, and because my only power source was the generator for 240v I ran it on the low setting. I moved the ground much closer and cleaned the metal better. I took the 1/8 stand off guard off and put the nozzle on the 1/8 plate and it cut right through like butter. I think I figured it out. Thank you a lot for the help it really did get me going in the right direction.
Thanks, Caleb |
Re: Plasma Help
Glad to help, with time spent with it you'll learn more & more.
Re: Plasma Help
you need a good ground if your working with painted
steel grind the a spot for the clamp |
| Tags |
| miller, plasma, plasma cutter |
