Old 02-12-2011, 12:01 AM
blake in spokane blake in spokane is offline
Jack Stands - Need Help!
I gota job coming up to build a couple jack stands 20,000 lbs.+ for big combine, big tractor, big ect. If I do a job they might want 4+. Any ideas?
Old 02-12-2011, 12:37 AM
DSW DSW is offline
Moderator
Re: Jack Stands - Need Help!
For something that heavy we've always used solid blocking, railroad ties, scrap chunks of wide flange or large dia. heavy wall pipe. How high do you need these to be? How much adjustment do they need/want? Can they simply be fixed height instead? (this makes it a lot simpler)
Ronald Reagan
Old 02-12-2011, 01:25 AM
quasi quasi is offline
I would be more than happy to build something like that but no way would I design it. Too much weight and liability.
Old 02-12-2011, 01:37 AM
oxygen454's Avatar
oxygen454 oxygen454 is offline
20000 lb = 10 t(US)
10 Ton jack stands...
~ Journeyman Steel Fabricator ~
Old 02-12-2011, 01:39 AM
oxygen454's Avatar
20000 lb = 10 t(US)
10 Ton jack stands... HERE
Sorry I cant go back and edit that last post as the picture moved the edit button off the screen.
Old 02-12-2011, 01:50 AM
700R 700R is offline
Copy some designs?
I like the square tube pin-style stands myself. Easy to make and strong as hell:
Miller Syncrowave 200 Runner
MillerMatic 180 AutoSet
Victor O/A (80cf)
Old 02-12-2011, 01:53 AM
Sorry for the huge pictures. Looks like Oxygen454 and I are on the same page...however Norco stuff is VERY expensive. The jackstands he posted are over $200, and the ones I posted are over $330! You can build a dozen of them for that price!
Victor O/A (80cf)
Old 02-12-2011, 10:26 AM
Errol @ TPS's Avatar
Errol @ TPS Errol @ TPS is offline
$300 is not at all expensive. You could not build a dozen of them for that. You may be able to buy a dozen's worth of material for that, but $300 would not cover the labor to cut up the material for a dozen, much less put them together.
