Old 02-12-2011, 12:58 PM
bmyers bmyers is offline
Weldanpower 225 woes
Got a weldanpower 225 awhile back and had to repair the oil/sump pan, which was cracked. I got the machine back together and have a problem or two:
1. The small wire that bolts to the engine on the back of the machine is causing some trouble. I believe this to be the kill wire. When it is unhooked, the machine seems to run fine..
2. The machine will not generate or weld at this time. I suspect these problems are related, but I am not for sure. I need to find a repair manual of some kind. I took the start/kill switch off and unhooked what would be the top right wire, looking from the back. The machine runs and seems to be idling right when I do this, whether or not the wire on the back is attached.
I do not have any way of knowing what wires are what, or what they should be carrying.
Any help would be greatly appreciated.
Thanks
Old 02-12-2011, 01:47 PM
GBM GBM is offline
Re: Weldanpower 225 woes
I am new here and new to my Weldanpower 225 ...
but I suspect those are two different problems...
the kill wire is just to turn off the engine..
you have another problem if , when running, it will not produce electricity..
if you search on this site I think someone has posted an electrical schematic for this machine...
But a quick trip to your local Lincoln dealer might solve the problem fast and cheap..
or perhaps you can email pics of the inside of your machine to them...
Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.
WW2 era Miller TIG.
Old 02-12-2011, 01:54 PM
prop-doctor's Avatar
prop-doctor prop-doctor is offline
have you checked lincoln electrics site for maunal
www.lincolnelectric.com search the service navagator
use your code model number
idealarc 250/250 ac-dc tig
idealarc 250/250 ac-dc tig #2 used for stick
lincoln sp100
hh125
dual arbor grinder polisher
30 yrs of hand tools
52 pitch blocks 6p-26p
rake gauge -pitch gauge
G&D prop repair
918-207-6938
Hulbert,okla 74441
Old 02-12-2011, 02:59 PM
roadkillbobb's Avatar
roadkillbobb roadkillbobb is offline
wheres DUANE....he should be called Mr,Lincoln..LOL.. he will appear soon and answer all your questions...
Old 02-12-2011, 03:02 PM
in the meantime if you goto the lincoln websight you can down load all the manuals you need, sorry I dont have the link at my fingertips
Old 02-12-2011, 04:32 PM
duaneb55's Avatar
duaneb55 duaneb55 is offline
Here's the link http://www.lincolnelectric.com/en-us...r-manuals.aspx bobb was talking about and we'll need to know the unit code # and engine make in order to know which 225 you're dealing with.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 02-12-2011, 08:33 PM
i will get the code asap. It is the Briggs 16 HP version.
Old 02-14-2011, 08:28 PM
The code is 9444
Model WP225G7
So i got it to generate for a bit tonight. It is acting very funky, which is why I am struggling to nail down the problem.
Wire #203 that attaches to ground on the engine at the back is the one that I was having to disconnect to get a spark. When I did that, It would run, but I had no output.
Today I had everything hooked up, and it started, ran, and generated fine. I shut it off to get a volt meter and came back. It started right up and ran fine, but is not making power now.
I did have the engine off, but got it all back together right, or at least how it was before.
It seems maybe I have 2 problems here. The larger concern for me is the generating/welding part.
Where should I start testing to see what the problem possibly is? It seems it may be fairly simple, but I am not sure where to check first. I have the wiring diagram and manual from Lincoln, but simply do not know where to start!
Old 02-15-2011, 01:17 AM
ccawgc ccawgc is offline
Wire 203 is the start /run / stop wire for the engine. Open engine runs. Connected to ground engine stops. Wire 203 connects to wire 5 in the start/ run / stop switch in the stop position.
Wire 203 also connects to wire 220 through the switch. 220 goes to the oil pressure switch.
Must have oil pressure for engine to stay running. This switch also supplies 12vdc to the pc board. No 12vdc to pcb no output. The switch is 3 , 3 position switches ganged together.
Check the run and oil pressure switches out, one or both may be bad. I hope you have enough oil in the engine so there is oil pressure.
Old 02-15-2011, 04:57 PM
Yes the engine is correct on oil. The run switch is the start/run/stop switch I assume? And for the oil switch, will it simply ground out if it is bad? If that is the case, I would think it wouldn't run at all.
Thanks a lot ccawgc for the help!
Old 02-15-2011, 09:11 PM
duaneb55's Avatar
Yes, the RUN switch is the RUN/START/STOP switch and I would check it for possibly being bad as well as ccawgc suggested.
If the OPS is bad (not opening with oil pressure) you would need to disconnect it not ground it. With no oil pressure the switch closes to connect to ground and shorts the engine ignition thru the RUN/START/STOP switch.
Also check the plug at PC1 for corroded terminals and pins which could be the cause of the intermittent weld/generator output.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 02-16-2011, 08:46 PM
Had a chance to do some more checking on the welder. so far I've found:
Wire 212A goes to the idler/high idle switch
Wire 212 goes to the board
wire 209A has 12V (not sure from where yet)
Wire 211 goes to the board
wire 211A goes back to the starter solenoid
wire 5G goes to ground??
wire 203 goes to ground at the back of the machine
wire 203A jumps from a post on the switch to 203.
I also tested the switch and can post a scan up of what I sketched out. I tested the switch for continuity between all 7 of the spades in all switch positions and cannot seem to understand what circuit it closes when you switch it to STOP.
Based on my testing of the switch I found that when the switch was in the RUN position:
-212 and 209A are closed together
-203A and 220 are closed together
In STOP position:
-5G and 203 are closed together
( this is what I don't quite understand)
In START position:
212 and 209 are closed together.
By closed together I mean had continuity.
I blew the diagram up and will check to verify they are at least all right, or as they are on the schematic. Any advice on checking the RUN switch? The oil pressure sensor switch is working.
thanks!
Old 02-16-2011, 10:58 PM
duaneb55's Avatar
209 gets 12vdc(+) thru the ammeter from the battery side of the starter solenoid.
In STOP position, 5G connects to 203 to ground (short) the engine ignition mag to stop the engine.
You should also find that 211/211A and 5G connect in START position. If so, the STOP/RUN/START switch checks out.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 02-17-2011, 01:59 AM
All # 5 wires are connected together. They are your battery minus and ground system.
The different letters show they are different wire segments.
On engines with magnetic ignition systems. A magnet passes a coil causing a pulse of electricity and making the spark. as long as the magnet keeps going by the coil it keeps working. Engine runs until it runs out of gas. To stop the engine when we want to. we take a coil wire and short it to ground and this kills the spark and stops the engine.
This explains the closed switch in the stop position.
The coil on your car is a step up transformer that needs 12vdc turned on and off to make spark.
One more thought. Make sure you do not have to much oil in the engine. This also causes problems.
Old 02-18-2011, 08:58 PM
duaneb55's Avatar
So bmyers, is this thing generating/welding again? I trust the engine starting/running/stopping issues are behind you. ??
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 03-01-2011, 10:33 PM
Hey Duane! Sorry for the delay I have been out of town and extremely busy. Had to get a few parts, and went ahead and put a carb kit on while I was at it. Got all the connections cleaned and everything put back together and it seems to be running great, but no power still.
Not sure where to go next on this. The start/stop switch checked out OK, but still no power, which would indicate that is/was not the problem.
Another small issue is I can not get it to idle down low enough. The mag is working, but it seems like it just won't pull back quite far enough. The idle screw is not the problem, as I backed it out plenty far. I have not messed with the spring system underneath, but I am afraid it may need adjustment- unless it is possible that the mag can get weak on these?
Thanks for all the help!!!
Old 03-03-2011, 11:13 PM
Ok I looked at the troubleshooting guide from lincoln and discovered a few things:
1. The slip rings measured 4.4 Ohms all the way around- good according to the manual.
2. Rheostat checked out ok. (1-10 Ohms)
3. I disconnected lead #4 and D2 (diode) and lead #5B. Tested continuity between the 2- came out ok.
The auto idle is in fact working, so I do not believe it is the board. No loose wires or connections that I can see anywhere.
Other things on the troubleshooting list include lead #5 from the "field rectifier". I am not sure where this is and cannot find it on the diagram. I found the field capacitor on the diagram. Any other ideas on why this thing wouldnt be welding/generating?
Old 03-05-2011, 08:38 AM
duaneb55's Avatar
Continuity between leads #4 and #5B confirms the field exciter output stator windings are OK. I don't have the specific voltage figure for this unit but when the generator is producing output, AC voltage on leads #4 and #5B is probably something in the neighborhood of 40-60 volts.
The "field rectifier" is that diode D2 that leads #4 and #5B attach to and is actually a full wave bridge rectifier that rectifies AC voltage to DC for the field exciter circuit to use after initial field flashing (excitation) from battery voltage.
The fact the AUTO IDLE is working only shows that portion of control board PCB1 is functioning. PCB1 performs several duties including initial field flashing to get things started which may be the root problem. An open flashing diode on PCB1 could be the cause and you can by-pass the board to test for generator/weld output by manually flashing the field at the brushes.
To do so, simply momentarily (a couple seconds) apply 12VDC to the rotor brushes circuits. There are several places you can do this to make it as easy as possible and you must apply the (+) and (-) to the correct wires such as:
12VDC(+)
1) wire #218 at the positive brush holder
2) wire #218 at the Fine Current Control rheostat
3) wire #200 at field rectifier D2
4) wire #200 at the Fine Current Control rheostat
5) wire #200A at the field capacitor
(For 3-5, Fine Current control should be set to Maximum)
12VDC(-)
1) wire #201 at the negative (-) brush holder
2) wire #201/201A at field rectifier D2
3) wire #201B at the field capacitor
4) any wire #5(x)
5) main chassis ground stud
(With the battery connected, properly grounded and charged, you should only need to connect 12VDC(+) to one of the points listed for it).
Pick any combination that makes it the easiest and make the connection for only a couple seconds. You should experience a significant arc when you remove the wire used for flashing so make sure you don't damage any stud threads or braided brush leads in the process.
If I'm not mistaken, if the flashing circuit on PCB1 is good, you should see 12VDC(+) battery voltage on wire #219. unfortunately, I don't have a board circuit diagram to be able to offer much board troubleshooting.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 03-06-2011, 11:21 AM
I will give this a try today. Thanks Duane!
Old 03-06-2011, 02:12 PM
Ok, I flashed the field using a 12V battery and fired the machine up. It is generating and welding now. I used the actual brush studs to flash the circuit with a set of wires I made. I did not experience a huge arc when I did it, but I do not know how big it should've been. I tested the voltage at D2 between #4 and #5B. It was around 20-30 VAC. Anyway, it seems to be running and generating fine. So, the question I would ask is- how long will it go working before the field needs "excited" again? If this happens again and I flash it and it works again, that tells me I basically need a new board correct?
Thanks a lot!
Old 03-06-2011, 02:28 PM
duaneb55's Avatar
Shouldn't have to unless you have an intermittent connection problem on the board (cracked solder joint) or bad harness connector terminal connection (dirty/corroded terminal).
Glad you got it working and keep us posted on its operation.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 03-06-2011, 07:56 PM
I certainly will keep everyone updated on how it is working. I had all 4 110V outlets running something ( drills, hand grinders, etc, while welding with some 1/8" rods. I burned a few of them up and it did not seem to have any problem at all.
Havent tested the 220 outlet yet, as most of my stuff has a different plug than what the welder has on it.
Thanks again for the help. I have learned a lot, not to mention saved some hard-earned $.
Old 03-13-2011, 02:04 PM
Went out today to get the cover cleaned up and put it back on and, well, it's doing it again. Last time I ended up re-charging or flashing the field and it woke up. I has only been around a week that it has sat. Nothing at all. No power, no weld, running good. Seems like the idler board may be giving fits, since I flipped it over to high idle and nothing changed. Any ideas?
Old 03-13-2011, 02:10 PM
If it is the idler board, does anyone have a good idea what one costs? I am guessing I would have to order from lincoln.
Old 03-13-2011, 02:20 PM
I have read that there is a capacitor that flashes the slip rings. If this is bad, there will be no output? If this is possible, where would this capacitor be found and how could I test it? Is this something that would be built into the board? Also, if this is the case, would it make sense that it ran after manually flashing it? If so, could I confirm it by maually flashing it again and seeing if it worked?
Sorry for so many questions! This thing is frustrating me because I thought I had it going.
Thanks
ben
HTML code is On
