Weekend Ring Roller
I finished a ring roller this weekend. This was a fun project. I was worried the whole time I was building it that it wouldn't work. Damned if it did!!
This is the drive roller. |
Base without the drive.
The other side.
All put together.
The first ring.
And a smaller one. I have no idea how to figure out what size rings it will make, or if I want a certain size, how much pressure to put on the metal to achieve it. I guess it's going to be trial and error. That's the way I do most things anyway
OH Yeah!, Did you just go off of a picture? I want to make one of these things..soon.
"after a long day of doing nothing...its gooood to kick back" Pumbaa |
Thats pretty darn slick, what did u do for rollers? And what is the flat bar closest to u doing? Cheers
It's based on this -- http://www.metalsmith.org/pub/mtlsmith/V20.3/roller.htm
I set out to make one like it, but the trial and error stuff took over. |
The rollers are 1 7/8 drill pipe with 1/4" plate for caps. The axles are 1/2 bolts. I think the flat bar your referring too is the handle for the drive roller.
Jim314
To make a certain size ring, figure out the circumference of the ring you want, cut your stock to that length & and start rolling. Keep rolling it smaller till the ends meet. Your ring is done. |
How to dimension ring stock ~ multiply the outside diameter of the ring x 3.14 to get the length of circumferance stock. Of course it's always a good idea to have a little extra stock so you don't have to fight with the ends.
You'll get a lot better rolling action if you drive 2 rollers, using a chain than you get with 1 driven roller. A steering wheel works a lot better than a crank too.
Appreciation Gains You Recognition- |
Nice work, now I need to make one.
Thanks for posting this. This is on the short list of shop projects, and i was planning on using the same design you did. I was really worried about 'grab' action with only one drive wheel. good to know it actually works.
How well would that work with square tube? say 1.5" .095 wall? I need to build a fancy gate for the misses. I dont need a full circle, more like an arch with about a 15 foot radius bend in it.
Well Franz, he hasn't been able to put a wheel on instead of the crank, as he needed the crank on there to make the wheel with. LOL
There's a nice roller/bender in the Metalworking.com drop box.
Of course, since it was built by a machinist, he got a bit exotic with some of the components. http://metalworking.com/DropBox/roller.txt http://metalworking.com/DropBox/roller.dxf
#22
Whoa Franz, that's way beyond my ability, not to mention my equipment. Hell, even if I had the equipment, it's still beyond my ability.
#23
#24
I keep tryin to tell you guys, these roller benders are just updated versions of a wheelright's tire roller from 100 years ago.
You want to frustrate hell out of yourself, reinventing the wheel, like that machinist did, fine by me, but if you want to build a bender, build one. Start by determining the minimum size you want to roll. make the rollers, and mount them.
#25
