7018 Questions
I've been using 7018 for about two weeks, mostly for practice, but have welded a few projects with it, and I have a question.
Striking an arc with it seems pretty easy and making a good looking bead is also not too much of a problem with some practice. The problem I'm having is that when I stop welding and then try to start again, I have to file the end of the rod to strike an arc. It seems that a film of flux forms a shinny film over the electrode and, unless I re-strike when the rod is still hot, I can't get the arc to start unless I file the end. Is this normal for this type of the rod or am I doing something wrong? Thanks; Steve
Lincoln Pro Mig 180 Everlast PowerARC 200
Re: 7018 Questions
Its completely normal... 7018s are hard to restrike, it just has to do with whats in the flux. I find its faster and way easier to hit the end of the rod on the tabletop and knock that piece off, but this can also take off a chunk of flux..
How do you like the rod?? Got any pics??
"Overkill is an often under-rated achievement" -Will Hayden HTP Mig 2400 Hypertherm Powermax 45 Lincoln Precision Tig 225 Longevity StickWeld 250 Hobart Stickmate AC/DC Hobart Handler 187 a.k.a ChuckE2009 on Youtube
Re: 7018 Questions
It always does that. I know if you shake off the last drip when you pull away, some of that goes away, otherwise you have to break the slag off the tip. That's what it is, slag.
Re: 7018 Questions
I'm working with 5/32 7018M on fillet T and now going to flat butt welds. Restriking is easy so long as I the raw flux not extend past the end of the rod where the slag has formed a thing layer. If that happens I just give it a brush with a finger ( glove on ofcourse ) and scratch the rod tip once.
Re: 7018 Questions
i pinch it between my gloved left thumb and forefinger and enough slag breaks off to allow contact to start the arc....
Re: 7018 Questions
I drag em on the concrete floor, quick whip, like Im striking a match.
If Im up in the air, welding pipe, as soon as Im done with said weld, I rub the tip between fore-finger and thumb, that limits the slag that solidifes on tip. Tears up gloves, but makes re-starts easier.
Lincoln Weldanpower 225 AC/DC-Briggs Lincoln 225/125 Tombstone Lincoln Weld-Pac 100 HD Jackson NexGen A Pile-O-Lee tools Sumner Ultra Clamps- where have these been all my life! DWM120 More pipe threading tools than I can list |
Re: 7018 Questions
Re: 7018 Questions
Thanks for the tips everyone. I've been keeping a file handy and filing off the tip, but some of the other suggestions are worth a try. I'll post some pictures of my welds soon as I get a chance.
Re: 7018 Questions
I also pinch the the flux off with my thumb & finger but I usually tap the end of the rod with the side of my slag hammer. Doesn't take much force to get rid of the slag layer left on the tip of the electrode and with the flux pinched off, it doesn't break off chunks.
Hobart Handler 120 Victor O/A Ramco Bandsaw Lincoln 225 AC Miller XMT304/22A & Extreme 12 VS Hypertherm Powermax 1000 G3 (home) Hypertherm Powermax 1650 G3 (work) Lincoln Idealarc DC600 Miller Digital Elite "Joker" SnapOn AD Hood |
Re: 7018 Questions
I use a my file. A couple of quick drags and it's gone. And I hardly ever chip the good flux.
"Stick-man is wise" - Farmall "Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550 "StickyFingers-man" Commander 500D, LN25 Shopmaster 300, Super S-32P Hypertherm Pmax 600 Smith & Oxweld O/P |
Re: 7018 Questions
Steven I take it as you're using your PowerArc 200? If so what brand of 7018 are you using?
I'm a big fan of ESAB's Atom Arc 7018, and my Dynasty loves it too. But I found my PowerArc 200 really likes Lincoln's Excalibur 7018, as does all my SA-200s. It may not matter to you at your level, but doing critical work with 7018 you'd be better off not to break the flux off before starting. A better way is to start your weld 1 to 1 1/2 inches in front of your direction of travel, and quickly drag the rod back to the start point. This helps get the rod up to temperature, which helps with nicer tie ins, and will be less chance of getting porosity in the weld pool.
Dynasty 300. V350-Pro w/pulse LF-72 SG Spool gun LN-25. PowerArc 200. 5 SA-200s. 1800 Ellis saw Powermax 1250, CNC table. PROFAX Welding Positioner. JD2 model 3
Re: 7018 Questions
Re: 7018 Questions
I love the Excalibur but most of the time I use 3/32". Got used to using it when I was doing maintenance on boiler systems.
Re: 7018 Questions
Excalibur runs fine and seems to put down lots of metal compared to other brands (1/8", 120+A). It wants to use a bit more amperage. Hobart 1/8" welds very well for a lot less money in the 7018 category. Last edited by GWD; 02-27-2011 at 09:05 AM. |
Re: 7018 Questions
Re: 7018 Questions
I have foudn the fastest way to handle this is to tap the end on the table to break the slag off before restriking - if good flux chips off I just strike the arc 1/2" into the weld then move back to the start point and weld over the restrike point.
Hobart LX235 Victor 250 Oxy-Acetylene Rig (welding and cutting) Bobcat 773 F-350, 1999, 4x4, 16' 10K# trailer Outdoor Wood Burner - 10 cords/year |
