Old 02-28-2011, 07:38 PM
johnywelds johnywelds is offline
Shop Drawings?
I'm a small time structural steel fabricator and am having problems bidding jobs because of the fact of producing shop drawings at the end. I don't understand why architects need them if you are doing exactly what they propose. I am capable of making them, but have not found a better way then the time consuming pencil and grid paper. Are there any inexpensive, simple programs for the computer that you have had success with? I am not very diligent with computers but know the basics. If anyone has advice i appreciate it.
Old 02-28-2011, 09:16 PM
Chrs Chrs is offline
Re: Shop Drawings?
Google sketchup is free and easy to learn/use. Once you're proficient its way faster and more professional than pencil and pad. There are many video tutorials. Check it out, maybe it will fit your needs.
Old 02-28-2011, 10:30 PM
Xtreme Fabrication's Avatar
Xtreme Fabrication Xtreme Fabrication is offline
Re: Shop Drawings?
Call a detailer company. I get my shop drawings from $100 to $300 per page. They are done by people who know what they are doing and come with PE stamps. I always include shop drawings as an addtional line item, not part of the bid price. Either the customers provides them or pays for them.
Lincoln
300 Vantage 2008
300 Commander 1999
SA250 1999
SA200 1968
Miller
Syncrowave 200
XMT350MPA/S-52E/xr-15
Xtreme 12vs
Millermatic 251 w/30A
Millermatic 251
Dialarc 250
Hypertherm 1250
GEKA & Bantom Ironwokers
Old 03-03-2011, 01:59 PM
djburton djburton is offline
Re: Shop Drawings?
Back when I was working with architects they had no problem with just making a copy of the details you were going to fabricate on your own letterhead and re-submitting them.
Shop drawings are a way for you to make more profit on the project if you can come up with a way to do the same job for less - but then you will take on responsibility. If you just re-submit the details they made you are only responsible for making the parts to the print provided.
Old 04-13-2011, 09:34 PM
robphillips00 robphillips00 is offline
Re: Shop Drawings?
Definitely don't leave that out of your bid cost. How are they submitting things to you for bid if they don't know what they want exactly?
That could be a bid disaster.
Old 04-27-2011, 10:06 AM
tenpins tenpins is offline
Re: Shop Drawings?
just part of the paper trail. Better suggestions are already given....just another one is to post in the wanted section of CL
Weldanpower 225 G7
Ironworkers Local #24
Old 04-27-2011, 12:15 PM
SmokinPRanch's Avatar
SmokinPRanch SmokinPRanch is offline
Re: Shop Drawings?
You said structural steel so there are some cautions with drawings. A drawing is a legal document which comes with liability.
It would be best to find an engineering firm that you can partner with. They will be familiar with the legalities and also produce professional quality drawings. A P.E. stamp is important but it won't get stamped if the design is not sound.
If you are dealing with real architects the design should already be validated and they should have provided drawings "for construction". Sounds like what they want from you are "as built" drawings. It is important that these be accurate. Any variation from the construction drawings can place a lot of liability on you.
If the client balks at the price of a set of real drawings beware. In that case it would probably be better to provide them the information and let them produce the drawings themselves. Which they should be able to do if they are architects.
Al
A man is judged by what's between his legs...always ride a good horse
Miller DialArc HF
Lincoln Classic 300D
Thermal Arc 181i
Powermax 45
Scotchman Ironworker
(2) Bridgeports
Okomota Surface Grinder
AutoCAD 2010
Old 04-27-2011, 02:42 PM
zora's Avatar
zora zora is offline
Re: Shop Drawings?
what he said. Sketchup does have a steep learning curve but once you figure it out you'll be miles ahead in terms of time saved. It is also nice that you have the dimensions of *everything* without having to calculate something on the fly. Nothing is worse than burning a couple hours adding 2" extensions on to a dozen pieces or so because you weren't thinking clearly when you cut them. Don't ask how I know.
ars sine scientia nihil est
Old 05-06-2011, 07:29 AM
Cecil654 Cecil654 is offline
Re: Shop Drawings?
A shop drawing is a drawing or set of drawings produced by the contractor, supplier, manufacturer, subcontractor, or fabricator Shop drawings are typically required for pre-fabricated components. Examples of these include: elevators, structural steel, trusses, pre-cast, windows, appliances, cabinets, air handling units, and millwork. Also critical are the installation and coordination shop drawings of the MEP trades such as sheet metal duct work, piping, plumbing, fire protection, and electrical.
[IMG] code is Off
