Old 03-02-2011, 10:09 PM
zapster's Avatar
zapster zapster is offline
Moderator
Flashback
Here is a link that was provided by a member about Flashback.
http://www.toolboxtopics.com/Gen%20I...0Flashback.htm
It happened to me so I thought it's best to make this a stickey..
Thank you jbmprods for the link!
...zap!
I am not completely insane..
Some parts are missing
Old 03-02-2011, 10:41 PM
jbmprods jbmprods is offline
Re: Flashback
your welcome Zap and glad it was just a wake up call. good idea you have hear to. lots of folks will see it.
225NT bobcat
AEAD200LE
Scott 125
mm175, mm252 w 30A, PT225
mm211, TA 181i
Hyper Therm 380, cut master 52
9100X & XX, Digital Elite
6 Victor sets
smith little torch, meco midget
kalamazoo band saw
steel max saw
evoulution circular saw
Old 03-05-2011, 11:42 PM
mb_welder's Avatar
mb_welder mb_welder is offline
Re: Flashback
A good combination is to have flashback arrestors at the regulators and check valves at the torch end.
The check valves are nice because they don't add a lot of bulk at the torch end.
And these are the arrestors.
Old 12-01-2011, 04:48 PM
farmall farmall is offline
Re: Flashback
When you inspect torches, keep an eye out for indications of internal fire damage such as heat discoloration.
This now-much-shorter Victor mixer left parts of itself in the tube when it melted. I guess the Smith and Airco designers have a point. Tip-mix torches don't do this:
Old 05-07-2012, 05:40 PM
jordan_5600's Avatar
jordan_5600 jordan_5600 is offline
Re: Flashback
good post...this is good to know...i always lite my torch with mixed gas so it does have all the black smoke.
...zap!
Old 07-29-2012, 09:55 AM
Fitshipper's Avatar
Fitshipper Fitshipper is offline
Re: Flashback
I would recommend investing in a newer torch with built-in flashback arrestors and reverse flow check valves. It is too easy to get in a hurry and not take the time to put these in the line to the regulators separately.
Ranger 225
Weld Pac 100
Power Mig 180C
Magnum 100 Spool Gun
Hobart EZ Tig 165i
Surf for cardiovascular exercise. Saltwater is good for you.
Old 12-12-2012, 04:09 PM
docwelder's Avatar
docwelder docwelder is offline
Re: Flashback
under what circumstances would anyone use acetylene over 15lbs? i find 10 lbs works fine for everything from sheet metal to 3" plate by changing the cutting tip to the correct size.
Old 12-12-2012, 07:47 PM
duaneb55's Avatar
duaneb55 duaneb55 is online now
Re: Flashback
This one provides an excellent visual of what takes place during those undesireable conditions.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
SA-200 Blackface Code# 8638
Star Jet 21-110
Old 12-12-2012, 08:43 PM
7A749's Avatar
7A749 7A749 is online now
Moderator
Re: Flashback
Excellent video Duane
Specializing In The Sale & Restoration Of
Miller 50 Series Wire Feeders
Miller Maxtron 450 Inverters
Old 12-12-2012, 09:20 PM
duaneb55's Avatar
Re: Flashback
Just reposted it Steve. Someone else did awhile back and I think the entire video series on proper setup and use should be a must watch for newbe OA torch users as well as a refresher for seasoned operators.
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Old 12-13-2012, 07:59 AM
7A749's Avatar
Moderator
Re: Flashback
I can watch stuff like that all day long.
I've been very fortunate & never had probs with my OA equipment.
Good info!
Old 02-12-2013, 09:39 AM
WelderBill's Avatar
WelderBill WelderBill is offline
Re: Flashback
Great thread with great info!.. The YouTube was nice too! Showing what can happen during a "flashback''!
How many on here have the flashback arrestors on their O&A setup ?
Thanks!
Hobart Handler 190
Hobart Spool-Gun 100
Lincoln 225 AC
Miller & Pipeliner Hood
Dewalt 14" Chopsaw, Grinders
Harris O/A
Victor Torch
Custom Built O/A Cart
Custom Welding Cart
Heavy Duty 16 Speed Floor Drill Press
Pipe-Bender
Drill Doctor
