Plate Weight
Hi being a bridge estimator taking off weight of plate is a daily job . The way Iearned is this formula. 3.40832 x number of pieces x thickness in inches x width in inches x length in feet = pounds example 1 plate .5 x 96" x 40' = 6535 lbs. Hope that helps ? Some use plate weight tables in pounds per square foot or 490 pounds per cubic foot. The easy way is to use Fabtrol punch it in and it weighs up and mults the plate for you . Hope this helps !! John
Re: Plate Weight
Ooops made a mistake 3.4832 is formula !!! John
Re: Plate Weight
Interesting.
Of course the multiplier can be eliminated if calculations don't mix feet and inches. I usually have to do the rough math in my head, and the shapes aren't always simple flats, so I go about it slightly differently. My favorite rules of thumb for carbon steel are: 40# per square foot @ 1" thick -or- 10# per square foot @ .250" thick -or- .283# per cubic inch. In practice, for easy math, I use: .250# per cubic inch and add 10% to the total if I need to get a little closer. ----------------- For the deck plates, I would probably have mentally calculated: 8' x 40' = 320 total square feet (then, because it's easy base-10 math: 320' @ 10# for 1/4' thickness) 320 x 10 = 3200# @ 1/4" thickness (then, because it's simple doubling) 3200 x 2 = 6400 @ 1/2" thickness For an estimate of 6400# vs the theoretical 6535# I may have been off by about 2%, -if the plates are 100% true and consistent- but that's usually close enough and I can crunch the numbers while pacing the dimensions as we talk about the weather. Good Luck Last edited by denrep; 03-06-2011 at 04:40 PM. |
Re: Plate Weight
I have found this useful
http://www.steelforge.com/steelweights.htm
A good guess is better than a bad measurement |
Re: Plate Weight
I have always used: Length X Width X Thickness X .2836 (Came out to 6534.144 pounds, must be close)
4 Miller Big Blue 600 Air Paks 2 Miller 400D 6 Lincoln LN-25's 4 Miller Xtreme 12VS 4 Miller XMT 350's 8 Miller Pro-300D 4 Climax BW-3000Z bore welders 4 T D Pro-152's Miller Dynasty 350 3 Linc DC-600 1 Linc 500-I Pair of Welpers |
Re: Plate Weight
Where does that .2836 come from?
AWS certified welding inspector AWS certified welder 44 years experience. Miller 110V 140 MIG Miller Elite auto sensing helmet. |
Re: Plate Weight
"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt |
Re: Plate Weight
Steel is 490 pounds per cubic foot. the formula I was taught is this, First you convert all your lengths to inches ( length X width X thickness) divided by a cubic foot which is (12x12x120) OR 1728.
so again that is length X width X thickness divide the answer by 1728, and then multiply this answer by the weight of the material per cubic foot, steel being 490. This works for all materials you just need to know the weight per cubic foot. If you are needing the weight of pipe its almost the same, Again you get all of your measurements converted to inches. take the diameter of the pipe X 3.1416 (PIE) X the length of the pipe X the thickness. Then divide by 1728 Then multiply by the material's weight per cubic foot And For round bar again in inches get the radius of the bar multiply the radius times itself X 3.1416 X length divide by 1728 then multiply by the material's weight per cubic foot |
