Old 03-13-2011, 05:32 PM
IceKid's Avatar
IceKid IceKid is offline
Arrow Side / Other Side
I wasn't sure where to ask this so I apologize if it is in the wrong section.
On a welding symbol, if depth, weld symbol, length and pitch are given on arrow side, but only depth and welding symbol are given on the other side, am I to assume that the length and pitch are the same as on arrow side?
TIA
Old 03-13-2011, 05:55 PM
sn0border88 sn0border88 is offline
Re: Arrow Side / Other Side
No, it should be specified on both sides. I would assume its continuous, but ask for clarification anyways.
Have we all gone mad?
Old 03-13-2011, 06:06 PM
Donald Branscom's Avatar
If there is single bracket for the length and pitch and it goes (above and below) the line, it is the same length and pitch for both sides
If there is a separate bracket above and below the line each bracket should specify.
From D1.1
AWS certified welder
44 years experience.
Miller 110V 140 MIG
Old 03-13-2011, 06:23 PM
IceKid's Avatar
I can't really ask for clarification as it is on a take home midterm test, lol. I can't seem to find it in my blueprint reading book, either, and I am assuming I am just missing it. I tried to draw it in paint and post a picture, I apologize for it looking so crappy, my paint skills leave much to be desired. The question is worded as: The length of the fillet weld, arrow-side is _________.
Old 03-13-2011, 06:25 PM
IceKid's Avatar
Oh and I know in my original question I switched the arrow-side/other-side specs but I didn't think I'd be posting a picture and didn't think it mattered if I switched it around, was just making it sound "easier"
Old 03-13-2011, 06:29 PM
I would say that the weld is going to be as long as the length of the piece the arrow side is referring too. Unless it is talking about the leg length.
Old 03-13-2011, 06:41 PM
CEP's Avatar
CEP CEP is offline
That would be a 1/2 inch fillet weld on the side the arrow is pointing to, with a 2 inch long weld 5 inches center.
1/8 inch fillet weld on the opposite side of where the arrow is pointing to.
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
Powermax 1250, CNC table.
PROFAX Welding Positioner.
JD2 model 3
Old 03-13-2011, 06:45 PM
CEP's Avatar
CEP CEP is offline
I re-read you post after posting, I guess one would assume the weld length would be the same on both sides. But you know what happens when we assume!
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
JD2 model 3
Old 03-13-2011, 07:26 PM
mrmikey mrmikey is offline
IMHO the 1/2" fillet weld would be the length of the joint it points to until it changes direction. I.e. one leg of an angle, one flange or web of a beam, one side of a tube etc.....Mike
Old 03-13-2011, 10:13 PM
tenpins tenpins is offline
If I was on the job, I would weld that half all out, given that symbol. It is unusual that there is not a length, or the "all around" symbol.
In all seriousness, I would call shenanigans on that question.
Old 03-14-2011, 01:33 AM
82VDubDiesel 82VDubDiesel is offline
How I read that symbol would be a 1/8" fillet 2" on 5"center on the arrow side, and a 1/2" fillet weld on the other side, full lenth because it has no lenth/ pitch specified. on prints I jenerally see it specified on both sides of the base line if they specify a lenth/ pitch specified. if the weld symbols are offset than you offset the welds from each other. (find center of the joint and lay the welds out for the first side from that point, then the other side off center bu splitting the pitch.)
Hope this helped
Travis
Old 03-14-2011, 03:52 PM
IceKid's Avatar
THANK YOU to everyone who responded! I think for now I'm going to leave it blank and confer with the other students and maybe just bring it up to the instructor.
Thanks for everyone's input
Old 03-14-2011, 04:14 PM
Unstaybull Unstaybull is offline
I/8 fillet 2-5 on OTHER SIDE......1/2 fillet till it changes direction on ARROWSIDE....
So answer to your question would be....Total length of weld seam until direction changes....
Old 03-15-2011, 11:00 AM
ICEKID,
You can just Google "weld symbols" and get all the answers.
Your computer is one of the most powerful tools in the world.
Miller 110V 140 MIG
Old 03-15-2011, 11:02 AM
Hope this helped
Travis
Good point 82DubDiesel. The welding symbol given was unusual.
Miller 110V 140 MIG
