Old 04-03-2011, 07:57 PM
Showdog75 Showdog75 is offline
sa200 question
I'd like to know if I were to go to a one-wire Delco alternator can I eliminate the voltage regulator on my 82 sa200 ? Is the any downside to going to a one-wire alternator ? Thanks
Old 04-04-2011, 07:12 PM
Nitesky Nitesky is offline
Re: sa200 question
No, you won't need the voltage regulator. I went to a stock GM alternator since it excites at lower rpms than a one-wire does. There is much information on this forum if you use the search function.
Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Old 07-15-2012, 07:08 PM
hobohilton's Avatar
hobohilton hobohilton is offline
Re: sa200 question
http://billswelderrepair.com/SA200starter.html
One wire that requires no regulator.
Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
HTML code is On
