Old 06-01-2006, 10:50 PM
Derek Derek is offline
Utility Trailer
I am currently making a utility Trailer. I was thinking of just using 3x2x1/4" Angle Iron for the Frame and supports under neath. I was considering using Channel but I only plan to use this trailer for a lawn tractor and just moving whatever I need to move.
Lets see some pics of the ones you guys have made, if you have. I would love to see them, maybe it'll give me some idea's.
Thanks,
Derek.
Old 06-02-2006, 08:43 AM
patrick mcdaniel patrick mcdaniel is offline
I made this one from 3" channel to haul my race car. You can scale it down for your use or maybe add an expanded metal floor.
Old 06-02-2006, 11:31 AM
TxRedneck's Avatar
TxRedneck TxRedneck is offline
sounds good...we love pictures
IF it Catches...Let it Burn
Old 06-02-2006, 11:37 AM
Very nice Patrick, how heavy is your race car? I was suprised to see only one axle. I know the commercial trailers are over-built as my dual axle open car trailer was bought. However it was large enough that I just hauled home a full size Chevy 2500HD on the back of it. Very happy with the unit. Well, with the exception of the ramps (badly designed)as they folded in half under the weight of the truck when very slowly pulling it on with a manual winch. I had to fillet the ramps, to bend the thick metal back, re-inforce it and finally welded on some tabs to hold the ramps down after them flopping up and down when loading a car on.
Your trailer looks as equally well built...good job!
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 06-02-2006, 03:34 PM
halbritt halbritt is offline
In the range of standard utility trailer axles, I've seen 6000Lb units that would probably suffice for a single-axle car trailer. There's a discussion on the relative merits of dual-axle vs. single-axle in a recent thread on utility trailer construction.
-Heath
Old 06-02-2006, 09:41 PM
GT_Man002 GT_Man002 is offline
Utility Trailer Project Weblink
Check out my Utility Trailer Project page.
http://www.gt1.homeip.net/project-trailer.htm
Regards,
Glen
Old 06-05-2006, 07:37 AM
Thanks for the kind words. My race car weighs in at 2100 lbs without the driver. I used a 3500 lb rated drop axle. It tows very straight. The key to single axle trailers is get the load balanced properly. I built the trailer in 2001 for cost of $550 excluding my labor. Sorry about not getting right back with you just got back in town.
Old 06-05-2006, 07:52 AM
Well done Gt Man. Excellant craftmanship. I like those tilt trailers. Nice sled we don't get enough snow my way or i would have one of those babies. Keep up the good work.
Old 06-05-2006, 11:55 AM
Patrick, excellent work. Post some pics of your car...I'd surely like to see them.
John
Old 06-05-2006, 01:06 PM
I will take some tonight.Along with some other projects i am workig on. I like pictures to.
Old 06-07-2006, 01:29 AM
Thanks Patrick,
Your trailer work looks great too. I like the simpleness (is that a word?) of your design!
Regards,
Glen
Old 08-25-2006, 07:22 PM
kanoa9321 kanoa9321 is offline
Re: Utility Trailer
Patrick, Nice trailer I am planning on building a very similar trailer for my car. How long is your trailer, only the bed section.
Thanks
Old 08-25-2006, 07:27 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: Utility Trailer
in my guesstimation you should have 4 wheels to start with and a surge brake system for 2 wheels at least....
race cars.. tools...parts... get heavy after awhile..
you may say "well i dont put that on my trailer"..maybe so but later on in life you'll want to...
if you have a race 300 miles away..better bring some spare tires...
have fun..
...zap!
I am not completely insane..
Some parts are missing
Old 08-26-2006, 05:43 PM
WHughes's Avatar
WHughes WHughes is offline
Re: Utility Trailer
Here is 6 1/2 X 10 trailer I made for a friend. It is made for quads and cycles. The ramp on the side folds up and is the height of the rest of the railing.
Still want to build a tilt, though.
Bill
Old 08-26-2006, 07:06 PM
chopper5 chopper5 is offline
Re: Utility Trailer
hear is my bike trailer
Chuck
ASME Pressure Vessel welder
Old 08-26-2006, 07:28 PM
elderthewelder elderthewelder is offline
Re: Utility Trailer
Bill
Bill
That is a sweet trailer, I sent you a PM, check you in box when you get a chance
Old 08-26-2006, 08:46 PM
peter14's Avatar
peter14 peter14 is offline
Re: Utility Trailer
Thats a sweet trailer,,Im doing an off road trailer,,I'll put it up when its a bit closer to being finished.
Theres no such thing as scrap metal,its all good.
