Old 04-19-2011, 01:34 AM
cc51's Avatar
cc51 cc51 is offline
Weld & Machine
An Accessory drive shaft out of a Cat 6 cyl diesel. An oil seal had worn it down about .020.
I hate rude behavior in a man.......Won't tolerate it! Woodrow F. Call
Old 04-19-2011, 12:09 PM
cc51's Avatar
Re: Weld & Machine
Hate it when that happens.
Old 04-19-2011, 08:55 PM
jackalope's Avatar
jackalope jackalope is offline
Re: Weld & Machine
Okay, what am I missing..................... It appears you tried to repair a worn shaft that was grenaded?!?!
http://jackalopefab.com/
Synchrowave 200DX
Miller XMT350 w/60series feeder
Miller Bobcat 250 with SGA 100 and spoolgun
HTP Plasma
Full Machine shop with everything
Old 04-19-2011, 10:48 PM
Oldiron2 Oldiron2 is offline
Re: Weld & Machine
The first shot shows the worn area partially welded while the second shows the same area (on the other side of the shaft) after machining. In Pic.2, the 'stuff' at the top right is remnants of insulation (shown at left in Pic. 1) that stuck, I'd guess.
Old 04-20-2011, 08:17 PM
mb_welder's Avatar
mb_welder mb_welder is offline
Re: Weld & Machine
shmutz!
