Hypotherm 1250
I have a chance to buy a used Hypotherm 1250, that needs some repair. The owner says it just quit working and he does not know what the problem is. He wants $150. Is this worth taking a chance on? Are these generally reliable machines? Are repairs expensive?
Any thoughts would be appreciated. |
Re: Hypotherm 1250
The seller says it is a Hypotherm, I assume he means Hypertherm.
Re: Hypotherm 1250
A 1250? I'd take a chance on it in a heartbeat - but ask him if he's take $100 due to the uncertainties.
Jim Colt here and the Tech crew at Hypertherm can give you a hand scoping it out.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Re: Hypotherm 1250
The Powermax1250 sold for around $4000 new....and is a very reliable system. It is worth the $150 easily....however it could be an expensive repair...or it could be very simple...there is no way to tell without doing some troubleshooting. You could pull off the cover ....look at the main large circuit board....and if you don't see any melted, burned components...then there is a better chance that the problem will be relatively minor. The Hypertherm Tech Servive department can help you troubleshoot the system once it is powered up.
Jim Colt Quote:
Re: Hypotherm 1250
If it comes with any consumables, that alone would make it worth the risk,
Miller Syncrowave 350 Millermatic 252/ 30A spoolgun Miller Bobcat 225g w/ 3545 spoolgun Lincoln PowerArc4000 Lincoln 175 Mig Lincoln 135 Mig Everlast 250EX Tig Century ac/dc 230 amp stick Victor O/A Hypertherm 1000 plasma |
Re: Hypotherm 1250
I am going to look at it on Saturday. After reading the specs it might be more cutter than I am looking for, as I will just be using it on small stuff in my garage.
Re: Hypotherm 1250
So.....fix it and trade it for something you really want. Or fix it and sell it. Then buy what you really want. If you have the power available to run it, there really isn't any reason not to go big.
My name's not Jim.... Syncrowave 200 Millermatic 251 w/bottle mod Spoolmatic 30A Maxstar 150s Cutmaster 81 Jet JTM-1 mill Jet GH-1340-W3 lathe |
Re: Hypotherm 1250
Well it ended up being a Powermax 350. Looks clean, but doesn't work. I decided to take a chance and bought it for $75. It has 4 sets of new tips.
Now I need to down load and print a manual. |
