Old 05-04-2011, 07:47 PM
russ69coupe's Avatar
russ69coupe russ69coupe is offline
Does all chrome moly tubing need to be Tig'd?
Looking at a mounting kit for a fiberglass front end on my current project car. Problem is it is made out of chrome moly. Don't have the size/gauge of the tubing, but it is smaller than roll bar stuff.
Thanks,
Russ
RIP Mallory, we miss you.
Old 05-04-2011, 07:51 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: Does all chrome moly tubing need to be Tig'd?
Tig is your best bet but Mig can be used...
No Fluxcore..
...zap!
I am not completely insane..
Some parts are missing
Old 05-04-2011, 10:03 PM
norite norite is offline
x2 what zapster said
Also oxy-acetylene is often used for building aircraft with c-m tubing..
SA 200
Idealarc 250 AC DC
MM200
MM251
30a Spoolgun & WC24 Control
Square Wave Tig 175
Invertec V350 Pro
SC-32 CS 12 Wire Feeder
Oxweld/Purox O/A
ArcAir gouging torch
Need Plasma
Old 05-05-2011, 11:29 AM
fortyonethirty fortyonethirty is offline
I would not pass up the opprtunity to TIG some 4130. Chromoly welds so nice I'd tig it just for fun. But, no you you don't have to tig it.
Ian Tanner
Kawasaki KX450f and many other fine tools
Old 05-05-2011, 01:24 PM
Donald Branscom's Avatar
How thin IS the tubing?
AWS certified welder
44 years experience.
Miller 110V 140 MIG
Old 05-05-2011, 02:24 PM
Pangea Pangea is offline
I welded lots of 4130 high pressure pipe for oil field use with MIG and Spray Arc. Pre heat to about 500 and use ER70S wire.
Two turn tables and a microphone.
